zfil
Jul 14, 2008Aspirant
Subversion : some progress
Hello I've managed to build a working subversion server : wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz First untar ...
wishyou
Dec 09, 2008Aspirant
da9l wrote:
Reinstalling APT addon (the latest seems to be dated 2008-10-31) in order to get the most recent and most correct sources.lists file.
Adding all libraries as described in the setting up development environment howto.
Running:
apt-get install python (the tests depends on python)
apt-get install coreutils (some stuff in configure is dependent on the uniq command)
apt-get install libtool (Might have something to do with our problem below)
Make sure that you do ./configure with all options again.
My god, you are good! :)
I've been banging my head against the wall for weeks over this...
Thank you!
Wish
