zfil
Jul 14, 2008Aspirant
Subversion : some progress
Hello I've managed to build a working subversion server : wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz First untar ...
enoesque73
Jan 25, 2009Aspirant
super-poussin wrote: sorry can you try libssl-dev ?
That now gives me:
# apt-get install libssl-dev
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libssl-dev: Depends: libssl0.9.8 (= 0.9.8g-10) but 0.9.8e-9 is to be installed
E: Broken packages
