zfil
Jul 14, 2008Aspirant
Subversion : some progress
Hello I've managed to build a working subversion server : wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz First untar ...
zfil
Jan 26, 2009Aspirant
This is strange
Because it is the correct thing: the dev lib depends on 0.9.8g-10 version I don't know why it is not installing the dependency ...
On my machine :
Usually I use something like that to have a running dev env, maybe you can try:
source.list
The following packages have unmet dependencies:
libssl-dev: Depends: libssl0.9.8 (= 0.9.8g-10) but 0.9.8e-9 is to be installed
E: Broken packages
On my machine :
# dpkg -l|grep libssl
ii libssl-dev 0.9.8g-10 SSL development libraries, header files and
ii libssl0.9.7 0.9.7e-3sarge5 SSL shared libraries
ii libssl0.9.8 0.9.8g-10 SSL shared libraries
apt-get update
apt-get install apt dpkg dpkg-dev
apt-get install libc6-dev gcc gdb libtag1-dev uuid-dev g++
apt-get install autoconf automake1.9 intltool libtool
apt-get install libssl-dev libexpat1-dev libapr1-dev libaprutil1-dev libcurl-dev
source.list
deb http://www.readynas.com/packages readynas/
deb http://archive.debian.org/debian-security sarge/updates main contrib non-free
deb-src http://archive.debian.org/debian-security sarge/updates main contrib non-free
deb http://archive.debian.org/backports.org sarge-backports main contrib non-free
deb-src http://archive.debian.org/backports.org sarge-backports main contrib non-free
deb http://archive.debian.org/debian sarge main contrib non-free
deb-src http://archive.debian.org/debian sarge main contrib non-free
