zfil
Jul 14, 2008Aspirant
Subversion : some progress
Hello I've managed to build a working subversion server : wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz First untar ...
enoesque73
Jan 28, 2009Aspirant
zfil wrote: Okay please can you reinstall libtag1 ? apt-get install libtag1
or if it is not working :apt-get --reinstall install libtag1
Hi zfil,
Thanks again for more assistance.
I tried
apt-get --reinstall install libtag1[/quote]
but still get
The following packages have unmet dependencies:
libtag1-dev: Depends: libtag1 (= 1.4-2bpo2.netgear2) but 1.4-2bpo2.netgear1 is to be installed
E: Broken packages
I then tried to do the --reinstall on every other package I'd installed BEFORE triying libtag1 again, but still get the same result.
I think I may have to give up at this stage, and instead use your downloadable tarball in viewtopic.php?f=35&t=23409&p=137837#p137837 instead.
Thanks again for helping with this one, even if I couldn't get it working.
eno
