zfil's avatar
zfil
Subversion : some progress
Hello
I've managed to build a working subversion server :
wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz
First untar both previously downloaded tgz.
cd subversion-1.5.0/zlib
./configure && make test && make install
cd ..
./configure --build=sparc-linux --enable-all-static --with-ssl --without-serf --with-zlib=/usr/local
make
make check
make install
56 tests out of 56 must run successfully.
The key is to build static otherwise svn and svnsync command coredump ...
The problem now is that the subversion server is very very slow, it is not a cpu problem, more a networking I think (the cpu is idle).
I'm using svnserve (svnserve -d), it is my usual setup on other platform and I never experienced any slowness (but it wasn't svn 1.5).
  • Thank you to everyone in this thread that contributed, including the issues and fixes. I was able to get subversion 1.6.17 working.
    I decided to use 1.6.17 rather than 1.7.0 because there was is no deps package available for 1.7.0. (Otherwise I would need to figure out how to get APR package installed and configured which is outside my expertise. I will try to remember the steps I took, and document the order which I did them.
    Please note, that I ended up running all the apt-get commands in the thread to ensure I was up to date with all required packages (especially since I updated apt sources list).
    I will describe a one named user configuration, no anonymous SVN access, via svn protocol (not http)
    FYI ./configure and compiling took about 2 hours.
    I followed the steps to "Setting up a ReadyNAS Development Environment" http://www.readynas.com/?p=145
    • started with a fresh factory default ReadyNAS (RAIDiator 4.1.7)
    • (follow the steps to create a development environment for the NAS) download EnableRootSSH and APT addons
    • installed those .bin files via FrontView, System>Update>Local
    • logged into my ReadyNAS via SSH (putty)
    • apt-get update
    • apt-get install nano (I'm not a vi wizard)
    • apt-get install gcc
    • apt-get install libc6-dev
    • apt-get install gdb
    • apt-get install libtag1-dev
    • apt-get install uuid-dev
    • wget http://subversion.tigris.org/downloads/subversion-1.6.17.tar.gz
    • wget http://subversion.tigris.org/downloads/subversion-deps-1.6.17.tar.gz
    • tar xvzf subversion-1.6.17.tar.gz
    • tar xvzf subversion-deps-1.6.17.tar.gz
    • rm *.gz (why keep the tarballs?)
    • change the file contents of /etc/apt/sources.list to the following:
      deb http://www.readynas.com/packages readynas/
      deb http://archive.debian.org/debian-security sarge/updates main contrib non-free
      deb-src http://archive.debian.org/debian-security sarge/updates main contrib non-free
      deb http://archive.debian.org/backports.org sarge-backports main contrib non-free
      deb-src http://archive.debian.org/backports.org sarge-backports main contrib non-free
      deb http://archive.debian.org/debian sarge main contrib non-free
      deb-src http://archive.debian.org/debian sarge main contrib non-free
    • apt-get update
    • apt-get install apt dpkg dpkg-dev
    • apt-get install libc6-dev gcc gdb libtag1-dev uuid-dev g++
    • apt-get install autoconf automake1.9 intltool libtool
    • apt-get install libssl-dev libexpat1-dev libapr1-dev libaprutil1-dev libcurl-dev (Note: I got an error installing libcurl-dev. but it didnt matter, as it was not a dependancy.)
    • apt-get install python (the tests depends on python)
    • apt-get install coreutils (some stuff in configure is dependent on the uniq command)
    • apt-get install libtool
    • cd subversion-1.6.17/zlib/
    • ./configure
    • make
    • make test
    • make build
    • cd ..
    • ./configure --build=sparc-linux --enable-all-static --with-ssl --without-serf --with-zlib=/usr/local
    • make
    • make check (note, this failed because some dependancy was missing, it is not critical to run the test suite)
    • make install
      Create svn user and group
    • echo svn:\!:100:102:svn:/c/home/svn:/bin/bash >> /etc/passwd
    • echo svn:x:102: >> /etc/group
    • mkdir -p /c/home/svn/repository
    • chown -R svn:svn /c/home/svn
      Create repository
    • su - svn
    • svnadmin create /c/home/svn/repository
    • cd repository/conf/
    • nano passwd
      Create the username and password in the file
      ### This file is an example password file for svnserve.
      ### Its format is similar to that of svnserve.conf. As shown in the
      ### example below it contains one section labelled [users].
      ### The name and password for each user follow, one account per line.
      [users]
      # harry = harryssecret
      # sally = sallyssecret
      myuser = mypassword
    • nano svnserve.conf
      a basic configuration, uncomment the settings and change as below:
      [general]
      anon-access = none
      auth-access = write
      password-db = passwd
      realm = Repository
      [sasl]
    • nano ../db/fsfs.conf
      to prevent an error during a SVN commit
      Error: no such table: rep_cache
      You'll need to disable your svn repository's cache to work around a bug in svn 1.6.5. To do that, just edit repository/db/fsfs.conf and add the following line (if it is there but commented out, remove the leading # to activate it):
      enable-rep-sharing = false
    • exit (get out of su mode)
    • nano /etc/services
      Add lines to /etc/services like these (if they don't already exist):
      svn           3690/tcp   # Subversion
      svn 3690/udp # Subversion
    • nano /etc/inetd.conf
      Add this line to /etc/inetd.conf:
      svn stream tcp nowait svn /usr/local/bin/svnserve svnserve -i -r /c/home/svn/repository
    • killall -HUP inetd
    • Finished!
ProSupport for Business
