BingDanT
Sep 23, 2018Aspirant
Tautulli Update has broken my system and lost all my data :(
Hi Mhynlo,
I was wondering if you could help me.
So heres the story:-
I had your original PlexyPY readynas app which worked great, and when it said update to Tautulli I did so with no problems ....
Skip to almost a year later and theres been a button on my readynas app page next to your Plexpy icon with Update (I've ignored it for awhile as my Tautulli/Plexpy installation has been working great since the update .... even the auto-updater worked a treat).
However i have notcied that Tautulli has been running a bit slower of late and I put this down to the 4000+ Records i had, so I hit your update button ....
To my horror the update stalled and didnt work and wiped my DB (Which i hadnt backed up, cause im an idiot).
So after multiple tries of getting plexpy from the app store installed and running i found your Tautulli install file which worked (Phew).
The only issue is its not great compared to your original Plexpy updated version.
Here are a couple of the issues ive found (Not including loosing me DB :( )
1) its allways says "You are running an unknown version of Tautulli." even when i try and auto-update i get this.
2) the auto-update crashed Tautulli every time i run it, which means i need to go into the Readynas Admin screen and stop then start the app again.
How can i fix these two issues ?
Cheers
Dan
1 Reply
- BingDanTAspirantAlso your version doesn’t have the newsletter functionality?
