767pilot's avatar
Oct 05, 2017
Wifi broken after firmware update
Everything was working fine and I decided to do the firmware update that I was told about via email from Netgear today. Everything went well except now I can turn on the wifi. I have tried every setting that I can find, rebooting, unplugging, etc. I need my wifi back!!!
Thanks in advance
  • Did you reset the router to factory settings after the firmware flash?
    New firmware sometimes introduces changes that are not compatible with the old configuration.
    So a factory reset is the first thing to try if you have problems with new firmware.
    First note down the settings – screen grabs can help here.
  • Having similar issue. Router settings hanging in update mode after new firmware initiated reboot. WiFi still works, but no way to make any additional changes to router settings.
    • Hammerhead11111's avatar
      Hammerhead11111
      Tutor
      Open CMD and ping the routers IP 198.162.1.1. If you do not get a responce this update killed your router. I also got that message, I also pdated my firmware we it was done it killed my router. Nothing I have tried let me gain acess to change the firmware back. If you do get a responce with a ping then u can get in to revert yuor firmware back to waht it was. If you get no responce from a ping its dead. I wont be buying anymore Netgear routers thats for sure.
  • michaelkenward's avatar
    michaelkenward
    • 767pilot's avatar
      767pilot
      Tutor
      Thank you, Michael. I'm glad that I didn't have the same problem that Mike did and as frustrated as I was, I am sure he feels even worse. No where in the directions did I see anything about doing a reset. If it's in there I missed it, if it's not in there perhaps it needs to be.
      Anyway, thanks for your help
        michaelkenward
        Hard to disagree with that.
        Maybe the technology does not allow Netgear to pass on such alerts.
  • The firmware update for my R6400 disabled my WiFi and I tried rebooting it with no success. I didn't even have the option to enable the SSID broadcast on the WiFi settings. I decided to change back to the previous Firmware Version (V1.0.1.24_1.0.18) and after it was installed and the router rebooted, everything worked. It was very frustrating to waste an hour and experience needless stress on a Friday. Here's the link to the R6700 firmware, if you want to try the same thing: https://www.netgear.com/support/product/R6700.aspx#download
      michaelkenward
      Rebooting already happens during the upgrade process. Doing it again gets you not further.
      Before going back to old firmware, with the security issues that this entails, do a factory reset.
      If that fails then you could try older firmware.
      • Des71's avatar
        Des71
        Tutor
        I went back to the older firmware with success.
