cat509
Feb 05, 2014Tutor
tiny tiny rss problem
I have just installed tiny tiny rss on my Nas312. When I go to the install page that comes up after hitting the Launch button from the Apps section of the admin console I put in the login name etc. that the instructions tell me to and after I hit the Test Configuration button on that page under Checking Database it comes back with the error message "Unable to connect to database using specified parameters". I'm using mysql because I have the mysql addon installed on my nas. What am I missing? How can I resolve the error message so I can move on to finish the installation process?
- aVe2000AspirantSame problem here...
there is a mysql server installed per default on our readynas (104). Do i have to additionally install the mysql addon? I cannot start the mysql addon on my nas.
Nvertheless, after installing ttrss i try to start ttrss.
The ttrss install site is shown where i have to enter some values:
mysql
user: admin
Password: password
Database: tiny
Then i try to test configuration. Config test passed but database test failed.
What is wrong here? How can i fix it?
Thanx for your help,
Regards - super_poussinVirtuosocan you try the 1.14 version which is in my community dropbox ?
- aVe2000AspirantHello Super-Poussin,
thank you for your reply. i did try the new version with the same result.
Checking configuration
Configuration check succeeded.
Checking database
Unable to connect to database using specified parameters.
Maybe some of the parameters are wrong? Does it interfer with other installations?
If you need a hand with debugging i will try to assist here. I have some basic linux knowledge.
Regards - aVe2000AspirantSuper-Poussin,
anything i can do to assist in fixing the addon?
Regards
