Sakthi4187
Mar 21, 2018Aspirant
Torrent Download location
Hi, Where should i found download file from inbuild torrent app. Thanks Sakthi
Mar 22, 2018Guru - Experienced User
What model ReadyNAS do you own, and what firmware is it running?
- Sakthi4187Mar 22, 2018Aspirant
Model : Ready nas 316
OS : 6.9.3
- Sakthi4187Mar 29, 2018Aspirant
Any Status?
- StephenBMar 29, 2018Guru - Experienced User
I don't use that particular app, my question was to get the basic information others would need to respond.
Hopefully mdgm-ntgr or another user who has this app running will respond.
- bedlam1Mar 29, 2018Prodigy
Which Torrent app have you got installed, there are 4
Transmission for ReadyNAS works well for me
Whichever you use you will need to specify a folder to save files to
