Sakthi4187
Mar 21, 2018Aspirant
Torrent Download location
Hi, Where should i found download file from inbuild torrent app. Thanks Sakthi
Sakthi4187
Mar 29, 2018Aspirant
Any Status?
Mar 29, 2018Guru - Experienced User
I don't use that particular app, my question was to get the basic information others would need to respond.
Hopefully mdgm-ntgr or another user who has this app running will respond.
- bedlam1Mar 29, 2018Prodigy
Which Torrent app have you got installed, there are 4
Transmission for ReadyNAS works well for me
Whichever you use you will need to specify a folder to save files to
- Sakthi4187Mar 29, 2018Aspirant
Am using μtorrent. In this i can able to dowload but i can`t find the downloaded location.
- bedlam1Mar 30, 2018Prodigy
OK you need to open UTorrent, user:admin password: (blank)
Click the "gearwheel" for settings
Select "Directories"
And enter the directory (one which you can find) where you want to save files to (a folder/share in /data is preferred)
Currently they are probably going into directories which are in /apps which is a "hidden" folder
