greerc
Jan 19, 2026Aspirant
Totally remove Plex?
I know that I can reinstall Plex. but what happens if I totally remove it? Then I can cleanly install it and any flags do not show up. It just trys to launch and fails, with the error that' 192.1...
- Jan 22, 2026
Perhaps try rebooting the PC.
Though not critical, since you were able to use ssh to resolve the original problem.
greerc
Unfortunely the second command where you type the net use command
did not work.
There are two ways to look for the pid file. One is to use ssh. The other is to access the NAS data volume with admin credentials. For example, run CMD and enter this:
net use * /delete /y
net use t: \\nas-ip-address\data /user:admin nas-admin-password
using the real NAS IP address and NAS admin password of course. Be care on the typing (both the slash directions and the spaces matter).
Then open file explorer, and enter T:\.apps\plexmediaserver\MediaLibrary\Plex Media Server in the address bar.
I get an error that it cannot find it. I must doing something
wrong.
So I just ssh'd in and looked for the problem ...and I found and then I rm the file.
I had this posted twice and your only one that responed. Any way it fixed it.
Jan 20, 2026Guru - Experienced User
greerc wrote:Unfortunely the second command where you type the net use command
did not work.
Can you post what you typed and what error you got?
Is the NAS using the default admin password (e.g., password)?
Also, are you using FlexRAID? If you are, then you need to use your volume name instead of "Data"
Note the two net use commands do need to be entered on different lines.
