greerc
Jan 19, 2026Aspirant
Totally remove Plex?
I know that I can reinstall Plex. but what happens if I totally remove it? Then I can cleanly install it and any flags do not show up. It just trys to launch and fails, with the error that' 192.1...
- Jan 22, 2026
Perhaps try rebooting the PC.
Though not critical, since you were able to use ssh to resolve the original problem.
greerc
Jan 21, 2026Aspirant
All I got were (After the t.. part) was NO response.
The NAS is not using the default password and I am using FlexRAID - But the name of the volume is DATA.
I get this when try type the commands.
C:\Windows\system32>net use * /delete /y - deleting all old connections
There are no entries in the list.
But now I get a different result as it says you have go delete them.
You have these remote connections:
T: \\192.168.1.29\data
Continuing will cancel the connections.
The command completed successfully.
And I get a System error 67 when I try the t; command. even if make sure I type two 'net use' first to get clean system.
I am talking to my NAS by files and by logging in to it.
- StephenBJan 22, 2026Guru - Experienced User
