Equinox1
Apr 14, 2016Guide
Transmission crashing after a couple of seconds
I've had the canonical Transmission plug-in installed on OS6 for months (the 3.0.8 that you install from the UI). Yesterday I noticed that there is a newer version on super_poussin dropbox, so I trie...
- Apr 14, 2016
yep now install the transmission interface package :) (also in my dropbox)
Equinox1
Apr 14, 2016Guide
So, this time I removed the whole Transmission share, uninstalled any previous versions via the UI.
I uploaded the new transmission deb file from the dropbox ( the one from a couple of minutes ago) and I get the following symptoms:
- UI says "installed succesfully";
- No Transmissions shows up in the installed apps list.
- Transmission still shows up in the available apps to install.
- No Transmission share has been created.
Any ideas?
super_poussin
Apr 14, 2016Virtuoso
- Equinox1Apr 14, 2016Guide
What file is that? transmissionr6_3.00.8_all.deb?
With transmissionr6_3.00.8_all.deb it worked, and seems stable. Now, I'll try to get the old config back.
Thanks for the help!
What was the problem?
- super_poussinApr 14, 2016Virtuoso
too much cpu optimization in compilation phase :P
