MattyShack
Aug 03, 2013Tutor
Update: Running VirtualBox VM host on ReadyNAS Pro 4.2.24
################################################################### ################################################################### ### VirtualBox is available in a number of package formats nat...
sander11
Mar 08, 2014Aspirant
Here is a copy of the last instructions I copied from when he posted them the passage below is (c) mattyshack 2014 "the Readynas community is forever in your debt!"
Replace weblink> with http:// and weblinks> with https:// had to replace due to forum posting constraints
### VirtualBox is available in a number of package formats native to various common Linux distributions
### Editor: Matty Shack
### Document Version: 4.3.2 (VirtualBox-4.3.2-90405)
### Publication Date: 22-November-2013
### VBox: 4.3.2
### PURPOSE: Provide instructions to install a functioning VBox on the ReadyNAS x86 running OS 4.2.x
This Guide will help you Install:
Python [2.7.6]
Php5 [5.4.21]
phpMyAdmin [4.0.9]
VirtualBox [4.3.2-90405]
phpVBoxManager [4.3-0]
# Oracle VirtualBox References:
# Home: weblink>www.oracle.com/technetwork/server-storage/virtualbox/downloads/index.html
# Latest Version: weblink>download.virtualbox.org/virtualbox/LATEST.TXT
# User Manual: weblink>download.virtualbox.org/virtualbox/UserManual.pdf
# SDK Ref: weblink>download.virtualbox.org/virtualbox/SDKRef.pdf
### WARNING: There may be typos and grammar missteps. I'm no expert or even a programmer,
### but this guide includes many hours of typing, trial, error and hair loss.
### I'm sure there are better ways to express different aspects of this guide and coding,
### so please be kind as you post recommendations for fixes and improvements.
### The lines that start with a ':' indicate that you have already followed this complete guide with success,
### but want to start over and try some new changes. For example, I messed up the permissions and could not
### get anything to work without deleting VBox and starting fresh. So I only needed to follow the ':' lines
### as all other relevant steps like, compiling the kernel, had not changed. Do not type the ': '. It is only
### used as a reference to identify the correct lines to focus on if you are conducting a partial rebuild.
### If the system reports that it cannot write because you are out of space, type 'df' to check disk space and 'df -i' to check for free i-nodes.
### Disk Space: There must be space available on the file system, meaning that there are still unused data blocks.
### i-Node Metadata blocks: Whenever a file is created on a file system, an inode is used to contain information about the file.
### Most file systems have a fixed amount of inodes. The available number of inodes are set during the mkfs operation of the file system.
### The only way to fix either problem is to free space/i-nodes by deleting files in /dev/md0. Start with your /root, /tmp, and /var/log directories.
### As you know, NetGear has moved on to their new ReadyNAS line [100/300/500 series] and, I assume, will give very little support to any prior model.
### That being said, VBox may extend the life of your server and allow it to be re-purposed beyond its creators' original intent.
### I ask that others on this forum continue to lend a helping hand as they share their knowledge and experiences
### with new users.
### Thanks
### *** My READYNAS Box Setup *** ###
# System: NetGear ReadyNAS Ultra 6, 6x3~18TB, 4GB Memory
# Installed Firmware: 4.2.24 ~ RNDP6xxx_4.2.24
# Linux OS: Debian v4.0 ~ Etch
# CPU Core: Intel dual core x86 (64 bit)
# NOTE: The original ReadyNAS series does not support CPU Hardware Virtualization (Hyper-V).
# This means that many advanced OS's like Windows8 or OSX will not run from these servers.
# I have upgraded my CPU from E2160 to an Intel dual core Q6600 running @ 2.4 GHz.
# As a result, I can now run Win8Pro in a VBox VM from my ReadyNAS.
# See thread weblink>www.readynas.com/forum/viewtopic.php?f=35&t=29284
### *** Target Files: Virtual Box 4.3.2-90405 (This install uses x86_64)*** ###
# VBox Runtime Linux x64: weblink>download.virtualbox.org/virtualbox/4.3.2/VirtualBox-4.3.2-90405-Linux_amd64.run
# VBox Runtime Linux x32: weblink>download.virtualbox.org/virtualbox/4.3.2/VirtualBox-4.3.2-90405-Linux_x86.run
# VBox Guest Additions ISO: weblink>download.virtualbox.org/virtualbox/4.3.2/VBoxGuestAdditions_4.3.2.iso
# VBox Extension Pack: weblink>download.virtualbox.org/virtualbox/4.3.2/Oracle_VM_VirtualBox_Extension_Pack-4.3.2-90405.vbox-extpack
### *** PHP Virtual Box Manager v4.3-0 *** ###
# REF: weblink>sourceforge.net/projects/phpvirtualbox/
# Remarks: VirtualBox 4.3.x Compatible --- 4.3-0 release
# This line may not work due to move from Google Code to Sourceforge
# wget `wget -q -O - weblink>phpvirtualbox.googlecode.com/files/LATEST.txt` -O phpvirtualbox-latest.zip
# wget -U IE6 -O phpvirtualbox-latest.zip weblink>downloads.sourceforge.net/project/phpvirtualbox/phpvirtualbox-4.3-0.zip
### KEY NOTES:
# These steps were performed on a 64bit x86 ReadyNAS system that was upgraded to firmware 4.2.24
# The ReadyNAS was also freshly cleaned using the 'Factory Default' boot setting.
# Therefore, you may experience dependency errors or system conflicts that I did not have during my VBox install.
# Also, I recommend that you set your ReadyNAS to a static IP Address so that VBox Manager will always see the same host IP.
# Lastly; If you are using Ethernet Teaming, ALB will interfer with VBox.
### Section A: Clean APT Repository, remove locks, and clear all cached deb files ###
### Refresh Packages from the APT repository ~ may help remove BADSIG messages ###
# Clear the APT Repositories
sudo killall apt apt-get aptitude
sudo -s -H
apt-get clean
rm -rf /var/lib/apt/lists/*
chmod 755 /var/lib/apt/lists
mkdir /var/lib/apt/lists/partial
chmod 755 /var/lib/apt/lists/partial
rm -rf /var/cache/apt/archives
mkdir -p /var/cache/apt/archives/partial
apt-get clean
# Replace File Locks
rm -rf /var/lib/dpkg/lock
sudo touch /var/lib/dpkg/lock
sudo chmod 640 /var/lib/dpkg/lock
rm -rf /var/lock/aptitude
sudo touch /var/lock/aptitude
sudo chmod 640 /var/lock/aptitude
rm -rf /var/lib/apt/lists/lock
sudo touch /var/lib/apt/lists/lock
sudo chmod 640 /var/lib/apt/lists/lock
rm -rf /var/cache/apt/archives/lock
sudo touch /var/cache/apt/archives/lock
sudo chmod 640 /var/cache/apt/archives/lock
### Update Sources.list ###
mv /etc/apt/sources.list /etc/apt/sources.list.bak
rm -rf /etc/apt/sources.list
sudo sh -c "cat >> /etc/apt/sources.list" <<EOF
deb weblink>archive.debian.org/debian etch main contrib non-free
deb weblink>www.readynas.com/packages readynas-x86/
deb weblink>www.readynas.com/packages 4.2.24/
deb weblink>packages.dotdeb.org squeeze-php54 all
deb-src weblink>packages.dotdeb.org squeeze-php54 all
deb weblink>packages.dotdeb.org stable all
deb-src weblink>packages.dotdeb.org stable all
#deb weblink>backports.debian.org/debian-backports squeeze-backports main contrib non-free
#deb weblink>ftp.debian.org/debian squeeze main contrib non-free
#deb weblink>download.virtualbox.org/virtualbox/debian squeeze contrib non-free
EOF
### Install Public Keys
gpg --keyserver pgpkeys.mit.edu --recv-key AED4B06F473041FA && gpg -a --export AED4B06F473041FA | sudo apt-key add -
gpg --keyserver pgpkeys.mit.edu --recv-key 8B48AD6246925553 && gpg -a --export 8B48AD6246925553 | sudo apt-key add -
wget -q weblink>www.dotdeb.org/dotdeb.gpg -O- | sudo apt-key add -
wget -q weblink>download.virtualbox.org/virtualbox/debian/oracle_vbox.asc -O- | sudo apt-key add -
apt-get update
apt-get --reinstall install nano curl gettext gawk sysutils
# Remove 32 Bit Kernel Modules
#rm -rf /lib/modules/2.6.37.6.RNx86_32.1.4
# Setup Build Source Area on /c/ Share
mkdir -p /c/addons-config/sysbuild/src/build
mkdir -p /c/addons-config/sysbuild/system
# want to see ***'s when entering the password at login
sudo visudo
# \-> Add: Defaults env_reset
# Allow Windows SMB network access
chown -R nobody:nogroup /c/addons-config/sysbuild
# Save Key System Files
cp /etc/apt/sources.list* /c/addons-config/sysbuild/system
cp /etc/host* /c/addons-config/sysbuild/system
cp /etc/passwd /c/addons-config/sysbuild/system
cp /etc/resolv.conf /c/addons-config/sysbuild/system
cp /etc/sudoers /c/addons-config/sysbuild/system
cp /frontview/conf/enclosure.db /c/addons-config/sysbuild/system
# Update Logger
find / -name logger
cd /usr/bin
ls -aFl logg*
mv logger logger.real
nano logger
#!/bin/bash
while getopts ":st:p:" Option
do
case ${Option} in
s | t | p ) cmdline="${cmdline} -${Option} ${OPTARG}" ;;
esac
done
shift $((${OPTIND} - 1))
busybox logger "${cmdline}" "${*}"
chmod +x logger
cp /usr/bin/logger /c/addons-config/sysbuild/src
### Pin APT and DPKG using the apt-get preferences file
apt-cache policy
apt-cache policy apt
apt-cache policy dpkg
apt-cache policy host
# Add the following lines to the end of the file:
echo "Package: apt" >> /etc/apt/preferences
echo "Pin: version 0.7.20.2+lenny2" >> /etc/apt/preferences
echo "Pin-Priority: 1001" >> /etc/apt/preferences
echo "" >> /etc/apt/preferences
echo "Package: dpkg" >> /etc/apt/preferences
echo "Pin: version 1.14.31" >> /etc/apt/preferences
echo "Package: host" >> /etc/apt/preferences
echo "Pin: version 20000331-9" >> /etc/apt/preferences
cat /etc/apt/preferences
cp /etc/apt/preferences /c/addons-config/sysbuild/system
apt-get -f install && apt-get autoremove && apt-get update
### Section B: Install VirtualBox Development Framework ###
# Setup the Build Environment to compile Kernel and Python
# If asked, select the [Default] setting
apt-get install \
amd64-libs \
binutils \
bison \
build-essential \
dialog \
fakeroot \
flex \
gdb \
gpp \
kernel-package \
lib64ssp0 \
lib64stdc++6 \
libbz2-dev \
libc6-amd64 \
libc6-dev-amd64 \
libcompress-zlib-perl \
libcurl4-openssl-dev \
libdb3-dev \
libgdbm-dev \
libncurses5-dev \
libpcre3-dev \
libsqlite3-dev \
libssl-dev \
libtag1-dev \
libtool \
p7zip \
p7zip-full \
par2 \
parchive \
uuid-dev \
zlib1g-dev \
zlibc
# Add local libraries so that the System can find them
cat /etc/ld.so.conf #include /etc/ld.so.conf.d/*.conf
sed -i '$d' /etc/ld.so.conf
echo "/usr/local/lib" >> /etc/ld.so.conf
echo "/usr/local/lib" > /etc/ld.so.conf.d/local_libs.conf
ldconfig -v
### Report System Data ###
# These next few lines will tell you more about your NAS
uname -r && uname -m
readelf -h $(which apt-get)|grep -E "Class|Machine"
## Full Name: 2.6.37.6.RNx86_64.2.4
## Kernel Series: 2.6.37.6
## Kernel Base: x86_64
## System Base: x86_32 (80386)
## *This means, for things other than kernel modules
## you need to install x86_32 ~ i386 binaries
### Update Selected System Files from Source ###
### Install CheckInstall from source ###
# REF: weblink>asic-linux.com.mx/~izto/checkinstall/
# Other method: fpm ~ weblinks>github.comf/jordansissel/fpm/blob/master/README.md
cd /c/addons-config/sysbuild/src/build
wget weblink>asic-linux.com.mx/~izto/checkinstall/files/deb/aaa_base_1.0-1.deb
dpkg -i aaa_base_1.0-1.deb
wget weblink>asic-linux.com.mx/~izto/checkinstall/files/source/checkinstall-1.6.2.tar.gz
tar xzvf checkinstall-1.6.2.tar.gz
cd checkinstall-1.6.2
make && make install
find / -name checkinstall
#--- Build deb package
checkinstall -D make install
# Select [y] to create docs -> choose yes (y) and enter a short summary of your package
# Package Summary: CheckInstall installations tracker, version 1.6.2
cp *.deb .. && cd ..
dpkg -i ./checkinstall_1.6.2-1_i386.deb
apt-get -f install && apt-get update
apt-cache policy checkinstall
checkinstall --version
## Upgrade file [5.14][5.04-5+b1 is installed] (This will also upgrade libmagic)
# weblink>freecode.com/projects/file
# The version of libmagic installed on the ReadyNAS is a limited version
# that does not support text or encoding checks, and does not define
# MAGIC_NO_CHECK_TEXT and MAGIC_NO_CHECK_ENCODING.
# Later on we will use python to link libmagic to python apps
# Make sure you link file and libmagic with python even if you already have python installed
wget ftp://ftp.astron.com/pub/file/file-5.14.tar.gz
tar zxf file-5.14.tar.gz
cd file-5.14
./configure
# Package Summary: file [5.14] compiled from source on Debian Etch (ReadyNAS 4.2.24)
cp *.deb ..
dpkg -i file_5.14-1_i386.deb
apt-cache policy file
ldconfig
file --version
## Upgrade xz-Utils [5.0.5][5.0.0 is installed]
# weblink>tukaani.org/xz
wget weblink>tukaani.org/xz/xz-5.0.5.tar.gz
tar zxf xz-5.0.5.tar.gz
cd xz-5.0.5
./configure
# Package Summary: xz-Utils [5.0.5] compiled from source on Debian Etch (ReadyNAS 4.2.24)
cp *.deb ..
dpkg -i xz_5.0.5-1_i386.deb
apt-cache policy xz
ldconfig
xz --version
## Upgrade gZxx [1.6][1.3.12 is installed]
# weblink>ftp.gnu.org/gnu/gzip
# Installs ~ gzip/gunzip/gzexe
wget weblink>ftp.gnu.org/gnu/gzip/gzip-1.6.tar.gz
tar -zxf gzip-1.6.tar.gz
cd gzip-1.6
./configure
# Package Summary: gZxx [1.6] compiled from source on Debian Etch (ReadyNAS 4.2.24)
cp *.deb ..
dpkg -i gzip_1.6-1_i386.deb
apt-cache policy gzip
gzip --version
gunzip --version
gzexe --version
## Install fuseiso-20070708 because iso mounting capability is not compiled into the ReadyNAS Kernel
## Ref: weblink>fuse.sourceforge.net
# Using fuseiso on a simple iso file. With the -p option, you do not need to create the mount point directory
# The mount point dir will be created when the iso is mounted and automatically removed when its unmounted
# mounting: fuseiso -p testimage.iso testimage_mountpoint
# unmounting: fusermount -u testimage_mountpoint
# See Chirpa's DVD ISO Guide
# REF weblink>www.readynas.com/forum/viewtopic.php?f=35&t=29874
apt-get install fuse-utils libfuse-dev libglib2.0-dev util-linux genisoimage
wget --no-check-certificate "weblinks>launchpad.net/ubuntu/+archive/primary/+files/fuseiso_20070708.orig.tar.gz"
tar zxf fuseiso_20070708.orig.tar.gz
cd fuseiso-20070708/
./configure
# Package Summary: fuseiso_20070708 compiled from source on Debian Etch (ReadyNAS 4.2.24)
cp *.deb ..
dpkg -i fuseiso_20070708-1_i386.deb
apt-cache policy fuseiso
ln -s /usr/local/bin/fuseiso /usr/bin/fuseiso
fuseiso -h
fusermount -V
# To avoid the automatic indexing of a mounted iso, add "fuse.fuseiso" to the end of the PRUNEFS="..." declaration
# This should prevent the updatedb command from indexing mounted iso directories
sed -i 's/tmpfs usbfs udf"/tmpfs usbfs udf fuse.fuseiso"/' /etc/updatedb.conf
cp /etc/updatedb.conf /c/addons-config/sysbuild/system
## Install ccd2iso [0.3]
# weblink>downloads.sourceforge.net/project/ccd2iso/
wget -U IE6 weblink>downloads.sourceforge.net/project/ccd2iso/ccd2iso/ccd2iso-0.3/ccd2iso-0.3.tar.gz
tar -zxf ccd2iso-0.3.tar.gz
cd ccd2iso-0.3
./configure
# Package Summary: ccd2iso [0.3] compiled from source on Debian Etch (ReadyNAS 4.2.24)
cp *.deb ..
dpkg -i ccd2iso_0.3-1_i386.deb
apt-cache policy ccd2iso
ccd2iso --help
## Install Other Linux ISO Utilities
# weblink>aneeska.com/2009/06/22/howto-install-extlinux-bootloader/
# weblink>shallowsky.com/linux/extlinux.html
apt-get install bsdtar syslinux mtools
find / -name extlinux
extlinux --help
Usage: extlinux [options] directory
--install -i Install over the current bootsector
--update -U Update a previous EXTLINUX installation
--zip -z Force zipdrive geometry (-H 64 -S 32)
--sectors=# -S Force the number of sectors per track
--heads=# -H Force number of heads
## OPTIONAL (NOT NEEDED) OK to SKIP
## Create Symbolic links between system files and /usr/local/bin Updates
rm -rf /c/addons-config/sysbuild/src/create_sym_links.sh
nano /c/addons-config/sysbuild/src/create_sym_links.sh
#!/bin/bash
# Title: create_sym_links.sh
# version: 1.0
# Author: Matty Shack
# Purpose: Bash script that creates symbolic links between an original and a duplicate file.
# The original file is copied to filename.bak and a symbolic link is created from the duplicate
# file to replace the original. The intent behind this script is to compile bin files from source
# and link them into the place originally held by the system file.
echo ""
# Test for arguments
if [[ $# -ne 2 ]]
then
echo "Usage: $0 Source-Location Destination-Location"
echo " Source = Directory path to Priority Files"
echo " Destination = Directory path to the location of files that will be saved"
echo " Example: $0 /usr/local/bin /usr/bin"
echo ""
exit 1
fi
echo "Source Location: $1"
echo "Destination Location: $2"
echo ""
cd $1
for file in $1/*
do
echo "Testing `basename $file`"
echo "$2/`basename $file`"
if [[ -f "$2/`basename $file`" ]]
then
echo "`basename $file` exists at both locations"
if [[ ! -f "$2/`basename $file`.bak" ]]
then
mv $2/`basename $file` $2/`basename $file`.bak
ln -s $file $2/`basename $file`
echo "`basename $file` -> Linked"
else
echo "`basename $file` is already backed up -> Skipping"
fi
else
echo "`basename $file` does NOT exist at both locations -> Skipping"
fi
echo ""
done
echo ""
echo "Process Complete!"
echo ""
chmod +x /c/addons-config/sysbuild/src/create_sym_links.sh
/c/addons-config/sysbuild/src/create_sym_links.sh /usr/local/bin /bin
/c/addons-config/sysbuild/src/create_sym_links.sh /usr/local/bin /usr/bin
ls /usr/local/bin
ls /bin/*.bak
ls /usr/bin/*.bak
### Remove Pinned MySQL packages from apt-get preferences
apt-cache policy
nano /etc/apt/preferences
# Remove the following using <CTRL-K>
Package: libmysqlclient15off
Pin: version 5.0.32-7etch8
Pin-Priority: 1001
Package: noflushd
Pin: version 2.7.5-2.netgear18
Pin-Priority: 1001
apt-get update && apt-get -y install noflushd
# Fix noflushd Error
# Change TIMEOUT= to TIMEOUT=30
sed 's/^TIMEOUT=/TIMEOUT=30/' /etc/default/noflushd > /etc/default/noflushd1 &&
mv /etc/default/noflushd1 /etc/default/noflushd
apt-get -f install
## Install Python [2.7.6] [skip if Python is already at this version, but be sure to connect libmagic to python]
# weblink>www.python.org/ftp/python
# For compatibility with sabnzbd/couchpotato/sickbeard, make sure your python version does not exceed sabnzbd requirements
# weblink>wiki.sabnzbd.org/install-off-modules
# So for now we will stay with Python-2.7.x series
# Get the Python source
rm -rf Python*
wget weblink>www.python.org/ftp/python/2.7.6/Python-2.7.6.tgz
tar -xzvf Python-2.7.6.tgz
cd Python-2.7.6
./configure
# Package Summary: Python 2.7.6 compiled from source on Debian Etch (ReadyNAS 4.2.24)
cp *.deb ..
dpkg -i python_2.7.6-1_i386.deb
apt-cache policy python
python -V
# Install python's setuptools
# REF: weblinks>pypi.python.org/pypi/setuptools
# weblinks>pypi.python.org/packages/ -> "Look for your python version then goto ../s/setuptools/ for your specific version of setuptools"
rm -rf setuptools*
wget --no-check-certificate weblinks>pypi.python.org/packages/2.7/s/setuptools/setuptools-0.6c11-py2.7.egg#md5=fe1f997bc722265116870bc7919059ea
sh setuptools-0.6c11-py2.7.egg
# Install Python PiP
find / -name easy_install
/usr/local/bin/easy_install pip
ln -s /usr/local/bin/pip /usr/bin/pip
pip install -U pip
# Connect libmagic to python
cd /c/addons-config/sysbuild/src/build/file-5.14
cd python && python setup.py install
file --version
# Install additional python packages
pip install libmagic
pip install ipython
pip install beautifulsoup4
## Install Binwalk [1.2.2-1]
# REF: weblink>binwalk.org/
# weblinks>github.com/devttys0/binwalk
# Install Python Prerequisites for Binwalk
apt-get install libpng12-dev libfreetype6=2.2.1-5+etch4 libfreetype6-dev
pip install numpy
pip install matplotlib
# Get BinWalk to start Walking
wget --no-check-certificate weblinks>binwalk.googlecode.com/files/binwalk-1.2.2-1.tar.gz
tar -zxvf binwalk-1.2.2-1.tar.gz
cd binwalk-1.2.2-1/src
binwalk --help
# Extract UNRAR and UNDVD from PRO-LLink AddOn using Binwalk
wget weblink>www.readynas.com/contributed/super-poussin/PRO-LLINK_3.0.bin
binwalk -re PRO-LLINK_3.0.bin
cd _PRO-LLINK_3.0.bin.extracted
tar xfz files.tgz
cd /c/addons-config/sysbuild/src/build/_PRO-LLINK_3.0.bin.extracted/usr/local/llink
mv undvd unrar /usr/local/bin
rm -rf /usr/local/sbin/undvd
ln -s /usr/local/bin/undvd /usr/local/sbin/undvd
rm -rf /usr/local/sbin/unrar
ln -s /usr/local/bin/unrar /usr/local/sbin/unrar
unrar
undvd
## Install Php5 [Currently:5.4.19-1 from weblink>packages.dotdeb.org] [skip if Php5 is already at this version]
## Solutions to common errors: weblink>www.robo47.net/text/6-PHP-Configure-und-Compile-Fehler
## Installs version: 5.4.21
apt-get install \
apache-dev \
apache2-prefork-dev \
automake \
byacc \
libbz2-dev \
libmcrypt-dev \
libmcrypt4 \
libmysqlclient-dev \
libmysqlclient15off=5.0.32-7etch12 \
libonig2 \
libqdbm14 \
libreadline5-dev \
libxml2=2.6.27.dfsg-6+etch1 \
libxslt1-dev \
libxslt1.1 \
libzzip-0-12 \
lsof \
mysql-common=5.0.32-7etch12 \
re2c
# Add local libraries to System
ldconfig -v
# Download, compile and install php5 from source
rm -rf php5*
apt-get source php5
cd php5-5*
cd pear
wget weblink>pear.php.net/go-pear.phar
cd ..
# Setup PHP directories
rm -rf /usr/local/php
mkdir -p /etc/php5/conf
mkdir -p /etc/php5/conf.d
mkdir -p /usr/local/php
# Link system files to support php compile
ln -s /etc/frontview/apache/httpd.conf /etc/apache2/httpd.conf
find / -name apxs*
ln -s /usr/bin/apxs /usr/sbin/apxs
ln -s /usr/bin/apxs2 /usr/sbin/apxs2
updatedb
# Compile Source Code
./configure \
--enable-mbstring \
--enable-soap \
--enable-zip \
--prefix=/etc/php5 \
--with-apxs2=/usr/sbin/apxs2 \
--with-bz2 \
--with-config-file-path=/usr/local/php \
--with-config-file-scan-dir=/etc/php5/conf \
--with-gettext \
--with-mcrypt \
--with-mhash \
--with-mysql \
--with-mysqli \
--with-readline \
--with-zlib
# Package Summary: PHP5 [5.4.21] compiled from source on Debian Etch (ReadyNAS 4.2.24)
zip ../php5-5.4.21.zip *.deb *.ini-*
cd ..
unzip php5-5.4.21.zip
dpkg -i php5_5.4.21-1_i386.deb
apt-cache policy php5
# Configure PHP5-php.ini
# Make sure Apache and Php5 are talking to each other
cp *.ini-* /etc/php5/conf
cp php.ini-production /usr/local/php/php.ini
sed -i 's/;include_path = "\.:\/usr\/share\/php"/include_path = "\/usr\/share\/php5:\/usr\/local\/php:\/usr\/local\/php\/lib\/php"/' /usr/local/php/php.ini
sed -i 's/;mysqli\.allow_local_infile = On/mysqli\.allow_local_infile = On/' /usr/local/php/php.ini
cp /usr/local/php/php.ini /c/addons-config/sysbuild/system
mkdir -p /etc/php5/apache2
rm -rf /etc/php5/apache2/php.ini
ln -s /usr/local/php/php.ini /etc/php5/apache2/php.ini
mkdir -p /etc/php5/cli
rm -rf /etc/php5/cli/php.ini
ln -s /usr/local/php/php.ini /etc/php5/cli/php.ini
# Configure PHP5-libphp5.so
find / -name libphp5.so
cp -rf /usr/lib/apache2/modules/libphp5.so /c/addons-config/sysbuild/system
cp /c/addons-config/sysbuild/system/libphp5.so /c/addons-config/sysbuild/src/build/php5-5.4.19/libs
libtool --finish /c/addons-config/sysbuild/src/build/php5-5*/libs
chmod 644 /usr/lib/apache2/modules/libphp5.so
# Configure PHP5-httpd.conf
nano /etc/frontview/apache/httpd.conf
# After the "LoadModule addonhandler_module /frontview/lib/mod_addonhandler.so"
# Look for these 3 lines - ADD any that are missing
LoadModule php5_module /usr/lib/apache2/modules/libphp5.so
AddType application/x-httpd-php .php
PHPIniDir /etc/php5/apache2
cp /etc/frontview/apache/httpd.conf /c/addons-config/sysbuild/system
# Backup Apache config
find / -name httpd.conf
# Configure PHP5-Phar
/c/addons-config/sysbuild/src/build/php5-5.4.21/build/shtool install -c /c/addons-config/sysbuild/src/build/php5-5.4.21/ext/phar/phar.phar /etc/php5/bin
ln -s -f /etc/php5/bin/phar.phar /etc/php5/bin/phar
# Configure PHP5-Links
/etc/php5/bin/php -v
cd /etc/php5/bin
ln -s /etc/php5/bin/pear /usr/bin/pear
ln -s /etc/php5/bin/peardev /usr/bin/peardev
ln -s /etc/php5/bin/pecl /usr/bin/pecl
ln -s /etc/php5/bin/phar /usr/bin/phar
ln -s /etc/php5/bin/php /usr/bin/php
ln -s /etc/php5/bin/php-cgi /usr/bin/php-cgi
ln -s /etc/php5/bin/php-config /usr/bin/php-config
ln -s /etc/php5/bin/phpize /usr/bin/phpize
# Show PHP5 version
php -v
## Add missing script usually found on Debian systems
nano /etc/mysql/debian-start
#!/bin/bash
# This script is executed by "/etc/init.d/mysql" on every (re)start.
# Changes to this file will be preserved when updating the Debian package.
source /usr/share/mysql/debian-start.inc.sh
MYSQL="/usr/bin/mysql --defaults-file=/etc/mysql/debian.cnf"
MYADMIN="/usr/bin/mysqladmin --defaults-file=/etc/mysql/debian.cnf"
MYUPGRADE="/usr/bin/mysql_upgrade --defaults-extra-file=/etc/mysql/debian.cnf"
MYCHECK="/usr/bin/mysqlcheck --defaults-file=/etc/mysql/debian.cnf"
MYCHECK_SUBJECT="WARNING: mysqlcheck has found corrupt tables"
MYCHECK_PARAMS="--all-databases --fast --silent"
MYCHECK_RCPT="root"
# The following commands should be run when the server is up but in background
# where they do not block the server start and in one shell instance so that they
# run sequentially. They are supposed not to echo anything to stdout. If you want
# to disable the check for crashed tables comment "check_for_crashed_tables" out.
# (There may be no output to stdout inside the background process!)
echo "Checking for corrupt, not cleanly closed and upgrade needing tables."
upgrade_system_tables_if_necessary;
check_root_accounts;
check_for_crashed_tables;
) >&2 &
exit 0
chmod +x /etc/mysql/debian-start
ln -s /etc/mysql/my.cnf /etc/mysql/debian.cnf
cp /etc/mysql/debian-start /c/addons-config/sysbuild/system
# Reboot NAS
reboot
## Install phpMyAdmin 4.0.9 is released (Mon, 04 Nov 2013 17:30:51 GMT). [If already installed, remove your version of phpMyAdmin and follow these steps]
REF: weblink>www.phpmyadmin.net/home_page/index.php
# Who owns Apache?
egrep 'User|Group' /etc/frontview/apache/httpd.conf
#>> Results: User:admin Group:admin
grep DocumentRoot /etc/frontview/apache/httpd.conf
#>> Results: DocumentRoot /frontview/ui/resource/html
rm -rf /frontview/ui/resource/html/info.php
sudo sh -c "cat >> /frontview/ui/resource/html/info.php" <<EOF
<?php
phpinfo();
EOF
chown -R admin.admin /frontview/ui/resource/html/info.php
# Restart Apache
killall apache-ssl
apache-ssl -f /etc/frontview/apache/httpd.conf
# Temp Start MySQL Service
start-stop-daemon -S -q -b -x /usr/sbin/mysqld -- \
--basedir=/usr \
--datadir=/var/lib/mysql \
--pid-file=/var/run/mysqld/mysqld.pid \
--skip-locking \
--socket=/var/run/mysqld/mysqld.sock
## Show php5 Info Page
## <Goto URL> weblinks>ReadyNAS_IP_Address/info.php
# Release additional repositories
#sed -i 's/#deb/deb/' /etc/apt/sources.list
#apt-get update
# Install phpMyadmin Prereqs for Standard Repositories
apt-get install \
php5-common=5.2.0+dfsg-8+etch16 \
php5-mysql=5.2.0+dfsg-8+etch16 \
libmcrypt4 \
libmysqlclient15off \
# Install Php Soap for VBox Remote Clients that may require it
apt-get install php-pear=5.2.0+dfsg-8+etch16 php-soap
rm -rf /etc/php5/apache/php.ini
ln -s /usr/local/php/php.ini /etc/php5/apache/php.ini
rm -rf /etc/php4/cli/php.ini
ln -s /usr/local/php/php.ini /etc/php4/cli/php.ini
rm -rf /usr/lib/apache/1.3/libphp5.so
cp -rf /usr/lib/apache2/modules/libphp5.so /usr/lib/apache/1.3/
# Download phpMyadmin
rm -rf phpMyAdmin-*
rm -rf /frontview/ui/resource/html/phpmyadmin
wget weblink>downloads.sourceforge.net/project/phpmyadmin/phpMyAdmin/4.0.9/phpMyAdmin-4.0.9-all-languages.tar.gz
tar zxf phpMyAdmin-4.0.9-all-languages.tar.gz
mv phpMyAdmin-4.0.9-all-languages /frontview/ui/resource/html/phpmyadmin
cd /frontview/ui/resource/html
ls -aFl
# Setup phpMyAdmin config
chown -R admin.admin phpmyadmin/
cd phpmyadmin
mkdir config
chmod o+rw config
cp config.sample.inc.php config/config.inc.php
chmod o+w config/config.inc.php
# Restart Apache
killall apache-ssl
--basedir=/usr \
--skip-locking \
## Setup phpMyAdmin to work with MySQL by using Wizard at URL
## NOTE: If you changed the MySQL User Root password
## Log into mysql as root and set it back to nothing ~ an empty password
mysql -uroot -p
mysql> UPDATE mysql.user SET Password=PASSWORD('') WHERE User='root';
mysql> FLUSH PRIVILEGES;
mysql> \q
## > Goto URL: weblinks>ReadyNAS_IP_Address/phpmyadmin/setup/
## Click on the <New Server> Button
## Look at /etc/mysql/my.cnf
## This will help set the
## Server configuration
## Your will see "Add a new server" {Basic settings} TAB
## [SELECT] <New Server>
## "Add a new server" {Basic settings} TAB
## Verbose Name of Server: ReadyNAS Pro/Ultra
## Server Hostname: localhost
## Server Port: 3306
## Server Socket: /var/run/mysqld/mysqld.sock
## Connection Type: socket
## PHP Ext to use: mysql
## [x] Connect without password
## "Add a new server" {Server configuration} TAB
## [x] Allow root login
## [x] Allow logins without a password
## <save>
## <save>
## Look for "Configuration saved" message
## Configuration saved to file config/config.inc.php in phpMyAdmin top level directory ...
## If you don't see this message, start over
## Close Browser Window
## Move Config File
cp -rf /etc/mysql/my.cnf /etc/mysql/my.cnf.bak
cp /etc/mysql/my.cnf /c/addons-config/sysbuild/system
cd /frontview/ui/resource/html/phpmyadmin
mv config/config.inc.php .
chown -R admin.admin config.inc.php
chmod 0755 config.inc.php
chmod o-rw config.inc.php
cp -rf config.inc.php /c/addons-config/sysbuild/system
rm -rf config
# Restart Apache
killall apache-ssl
--basedir=/usr \
--skip-locking \
## Test phpMyAdmin
## > Goto URL: weblinks>ReadyNAS_IP_Address/phpmyadmin/index.php
## Username: root
## Password:(empty)
## <GO>
# you should see these databases or more: information_schema, mysql, and slimserver
## NOW: Install the ReadyNAS {Photos II} addon to permanently activate the ReadyNAS MySQL Server
## Once activated, MySQL will start during boot
## Clear the Root Directory and copy files to /c/addons-config/sysbuild/root.bak
# Clear /root/src to avoid inode space issues
df && df -i
cd /root
mkdir -p /c/addons-config/sysbuild/root.bak
cp -rf * /c/addons-config/sysbuild/root.bak
rm -rf /root/*
# Create tar.xz backup to USB @ /USB_FLASH_1/
#cd /c/addons-config/sysbuild
#rm -rf /USB_FLASH_1/sysbuild.tar.xz
#tar -Jcvf /USB_FLASH_1/sysbuild.tar.xz .
# Restore tar.xz backup from USB @ /USB_FLASH_1/
#rm -rf /c/addons-config/sysbuild
#mkdir -p /c/addons-config/sysbuild
#tar -Jxvf /USB_FLASH_1/sysbuild.tar.xz -C /c/addons-config/sysbuild
### Section C: Build and Patch the Kernel ###
### Compile new Kernal with VBOX Modules
# The Kernel must be built on the /c/ drive to avoid space limitations
mkdir -p /c/addons-config/VirtualBox/backup
# Install Oracle Key from source
cd /c/addons-config/VirtualBox/backup
wget weblink>download.virtualbox.org/virtualbox/debian/oracle_vbox.asc
sudo apt-key add oracle_vbox.asc
apt-get update
### Section C1: Download the Kernel Patch Kit ###
### Get ReadyNAS Kernel-Build-Tools [RAIDiator-x86-V4.2.24_WW_src.zip]
# weblink>www.downloads.netgear.com/files/GPL/ReadyNAS/RAIDiator-x86-V4.2.24_WW_src.zip
### Download ReadyNAS Kernel-Build-Tools
rm -rf kernel
rm -rf /usr/src/linux*
wget weblink>www.downloads.netgear.com/files/GPL/ReadyNAS/RAIDiator-x86-V4.2.24_WW_src.zip
unzip -q RAIDiator-x86-V4.2.24_WW_src.zip "kernel/*"
mv kernel ..
### Section C2: Build VirtualBox Kernel Environment ###
## Make a copy of unmodified ReadyNAS Linux Kernel Source
cd /c/addons-config/VirtualBox/kernel/2.6.37
cp -rf linux-2.6.37.6 ./linux-2.6.37.6-original
# <> Starting Over? : Restore the copy of the unmodified ReadyNAS Linux Kernel Source you just made
# : cd /c/addons-config/VirtualBox/kernel/2.6.37 && rm -rf linux-2.6.37.6 && rm -rf /usr/src/linux* && cp -rf linux-2.6.37.6-original linux-2.6.37.6
## Apply NetGear patches to ReadyNAS 2.6.37.6 Kernel Code
: cd /c/addons-config/VirtualBox/kernel/2.6.37/linux-2.6.37.6/
: chmod +x ../netgearize_kernel.sh
: ../netgearize_kernel.sh
## Align Kernel Tree with location of Linux Source
ln -snf `pwd` /usr/src/linux
export KERN_DIR=/usr/src/linux
## Link Linux headers to build modules properly
cd /usr/src/linux/include/linux
ln -s ../generated/autoconf.h .
ln -s ../generated/utsrelease.h .
rm -rf /usr/src/linux-headers-*/
ln -s /usr/src/linux /usr/src/linux-headers-$(uname -r)
cd /lib/modules/$(uname -r)
rm -rf build
rm -rf source
ln -s /usr/src/linux-headers-$(uname -r) source
ln -s /usr/src/linux-headers-$(uname -r) build
## Setup the Build Process for a ReadyNAS Kernel
: cp arch/x86/configs/defconfig.smp .config
: make ARCH=x86_64 oldconfig
: mkdir -p /usr/src/linux/include/config
: rm -rf /usr/src/linux/include/config/auto.conf
: ln -s /usr/src/linux/.config /usr/src/linux/include/config/auto.conf
: make prepare
: make modules_prepare
## Start the Build!
: make
: make -C /lib/modules/`uname -r`/build modules
### Section D: Install VirtualBox-4.3.2-90405 ###
### REF: weblink>download.virtualbox.org/virtualbox/
### Note: Python must be installed and working before continuing
# Download VBox Runtime and Ext Pack
: cd /c/addons-config/VirtualBox/backup
wget weblink>download.virtualbox.org/virtualbox/4.3.2/VirtualBox-4.3.2-90405-Linux_amd64.run
wget weblink>download.virtualbox.org/virtualbox/4.3.2/Oracle_VM_VirtualBox_Extension_Pack-4.3.2-90405.vbox-extpack
: chmod 755 VirtualBox-4.3.2-90405-Linux_amd64.run
## Make sure System is Clean from prior install
: ./VirtualBox-4.3.2-90405-Linux_amd64.run uninstall
: rm -rf /opt/VirtualBox
: mkdir /opt && chown -R root:root /opt
: rm -rf /root/.VirtualBox
: rm -rf /etc/vbox
: rm -rf /home/vbox
: rm -rf /usr/src/vboxhost*
: rm -rf /var/log/vbox-*.log
: rm -rf /etc/init.d/vbox*
: rm -rf /etc/default/virtualbox
: rm -rf /usr/share/virtualbox
: rm -rf /lib/modules/`uname -r`/vbox*.ko
: rm -rf /lib/modules/`uname -r`/kernel/drivers/target/vbox*.ko
## Install VBox Runtime with source code for VBox Kernel modules
# This creates the '/opt/VirtualBox' directory and compiles VBox kernel modules
# A user's manual can be found at '/opt/VirtualBox/UserManual.pdf'
: modprobe -l
: dmesg | grep vbox
: nano /var/log/vbox-install.log
## Fix error while loading shared libraries: libcrypt.so.1
# Apparently, the 32-bit libcrypt.so is in the root image, but not the 64-bit one.
apt-get --reinstall install libc6-amd64
# Check that root owns the /opt Directory
ls -ld /opt
# Execute this line to change owner to "root"
: chown root /opt
# Install VirtualBox Extension Pack
: /usr/bin/VBoxManage extpack uninstall "Oracle VM VirtualBox Extension Pack"
: /usr/bin/VBoxManage extpack install Oracle_VM_VirtualBox_Extension_Pack-4.3.2-90405.vbox-extpack
: /usr/bin/VBoxManage list extpacks
# Setup default VirtualMachine folders of VBox
# I store all original downloaded VM's into backup/images (leave compressed)
# I store all downloaded VM's into importimage that I'm using in VBox (uncompressed)
# I save all VBox exported VM's into exportimage (give them to all your friends)
mkdir -p /c/addons-config/VirtualBox/backup/images/unpacked
mkdir -p /c/addons-config/VirtualBox/VirtualMachines/importimage
mkdir /c/addons-config/VirtualBox/VirtualMachines/exportimage
mkdir /c/addons-config/VirtualBox/VirtualMachines/working
# Allow Windows SMB File Service access
chown -R nobody:nogroup /c/addons-config/VirtualBox/backup
chown -R nobody:nogroup /c/addons-config/VirtualBox/kernel
chown -R nobody:nogroup /c/addons-config/VirtualBox/VirtualMachines
# Use linked directories to put the VBox Guest Additions ISO into a location that is searched by the phpVirtualBox Manager
: ln -snf /opt/VirtualBox/additions /usr/share/virtualbox
# Compile VirtualBox kernel modules
cd /usr/src/vboxhost-4.3.2
make
# Copy VBox Modules into the directory matching your kernel release from uname -r
# If you have RAIDiator 4.2.24 installed, it should match 2.6.37.6.RNx86_64.2.4
# This should allow VBox to survive a ReadyNAS firmware upgrade as long as the kernel base version remains 2.6.37.6.RNx86_64.2.4
ls -aFl
uname -r
cp -rf *.ko /lib/modules/`uname -r`/
cp -rf *.ko /lib/modules/`uname -r`/kernel/drivers/target/
# Just to be sure everything worked, we will now force the recompilation of the VBox Kernel modules
# If there are errors, check the /var/log/vbox-install.log file to find out why the compilation failed
: sudo /etc/init.d/vboxdrv setup
### Test VBox System for Driver Install ###
# Stop VirtualBox Service
/etc/init.d/vboxdrv stop
# Start VirtualBox Service
/etc/init.d/vboxdrv restart
### End Test
## Backup Kernel Directory into a TAR file named "VBox_Linux_Kernel_2.6.37.6_ReadyNAS_4.2.24.tar"
cd ../ && tar -cf /c/addons-config/VirtualBox/VBox_Linux_Kernel_2.6.37.6_ReadyNAS_4.2.24.tar linux-2.6.37.6/ && cd linux-2.6.37.6/
mv /addons-config/VirtualBox/VBox_Linux_Kernel_2.6.37.6_ReadyNAS_4.2.24.tar /addons-config/VirtualBox/backup
rm -rf /c/addons-config/VirtualBox/kernel
## <> Starting Over? : Restore the Backup you just made!
#mkdir -p /c/addons-config/VirtualBox/kernel/2.6.37/
#cd /addons-config/VirtualBox/backup
#tar xf VBox_Linux_Kernel_2.6.37.6_ReadyNAS_4.2.24.tar -C ../kernel/2.6.37/
### Section E: Install phpVirtualBox and FSniper ###
# phpVirtual Box allows you to work with your ReadyNAS VirtualBox from a web browser
# It is an open source, AJAX implementation of the VirtualBox user interface written in PHP.
# As a modern web interface, it allows you to access and control remote VirtualBox instances.
# Much of its verbage and some of its code is based on the (inactive) vboxweb project.
# phpVirtualBox was designed to allow users to administer VirtualBox in a headless environment
# - mirroring the VirtualBox GUI through its web interface.
### Note: PHP must be installed and working before continuing ###
## Six (6) Easy Steps: This will surely get you to Narnia or Never Never Land
## You should complete Steps [1 - 4]. However, Steps [5 - 6] are optional.
# Let's get this party started
## Step 1: Add user VBOX to group VBOXUSERS
addgroup vboxusers
adduser vbox --no-create-home --ingroup vboxusers
## Sample Output: You will provide a new xxx password
# Adding user `vbox' ...
# Adding new user `vbox' (1004) with group `vboxusers' ...
# Not creating home directory `/home/vbox'.
# Enter new UNIX password: xxx
# Retype new UNIX password: xxx
# passwd: password updated successfully
# Changing the user information for vbox
# Enter the new value, or press ENTER for the default
# Full Name []: vbox
# Room Number []:
# Work Phone []:
# Home Phone []:
# Other []:
# Is the information correct? [Y/n] Y
# Give User vbox ownership of Image Storage Directories
adduser vbox vboxusers
chown vbox:vboxusers ./VirtualMachines/importimage/
chown vbox:vboxusers ./VirtualMachines/exportimage/
chown vbox:vboxusers ./VirtualMachines/working/
## Create addons-config Share using FrontView:
# FrontView: [Shares] [Add Shares] [Name: addons-config] [Description: Addons-config Share] [Apply]
# FrontView: [Share Listing] [CIFS ~ addons-config] [Advanced Options]
# Share folder owner: nobody
# Share folder group: nogroup
# Share folder owner rights: read/write
# Share folder group rights: read/write
# Share folder everyone rights: read/write
# [x] Set ownership and permission for existing files and folders in this share to the above settings.
# [x] Grant rename and delete privileges to non-owner of files.
# [Apply]
## Step 2: Install phpVBoxManager for ReadyNAS
# Download PHPVBoxMgr_0.4-readypro-0.1.1.bin
# Site: weblink>netgear.tonidoid.com/app/webshare/share/NETGEAR%20ReadyNAS%20Tech%20Documents/Add-on/x86/?vm=list
## NOTE: If PHPVBoxMgr_0.4-readypro-0.1.1.bin is missing and cannot be downloaded, no big deal. Just skip to Step 3.
wget weblink>netgear.tonidoid.com/app/webshare/share/NETGEAR%20ReadyNAS%20Tech%20Documents/Add-on/x86/PHPVBoxMgr_0.4-readypro-0.1.1.bin?action=download
mv PHPVBoxMgr_0.4-readypro-0.1.1.bin\?action\=download PHPVBoxMgr_0.4-readypro-0.1.1.bin
## Install phpVBoxManager using FrontView:
# FrontView: [Add-ons][Add New] then [Browse]: \\ReadyNAS_IP_Address\addons-config\VirtualBox\backup
# <Select>: PHPVBoxMgr_0.4-readypro-0.1.1.bin
# FrontView: [Upload and verify image..][Warning][OK] then [Install]
# FrontView: [Add-ons][Installed] -> Verify that you see PHPVBoxMgr
# Do not attempt to Edit or [Load Config] from FrontView's VirtualBox Manager
## Now, close the Browser Window and go back to the terminal screen
cp /frontview/ui/resource/html/phpvboxmgr/config.php /addons-config/VirtualBox/backup/PHPVBoxMgr_0.4-readypro-0.1.1-config.php.orig
## Step 3: Upgrade phpVBoxManager from v0.4 to v4.3-0
### *** PHP VirtualBox Manager v4.3-0 *** ###
# Remarks: VirtualBox 4.3.x Compatible = VirtualBox Manager 4.3-0 release
## Download the Latest version of phpVBoxManager:
rm -rf phpvirtualbox*
unzip phpvirtualbox-latest.zip -d phpvirtualbox-4.3-0
cp /addons-config/VirtualBox/backup/phpvirtualbox-4.3-0/config.php-example /addons-config/VirtualBox/backup/phpvirtualbox-4.3-0/config.php
: rm -rf /frontview/ui/resource/html/phpvboxmgr/
: cp -rf /addons-config/VirtualBox/backup/phpvirtualbox-4.3-0 /frontview/ui/resource/html/phpvboxmgr
## Step 4: Edit PHP VirtualBox Manager Configuration File
# Location of file: /frontview/ui/resource/html/phpvboxmgr/config.php
: nano /frontview/ui/resource/html/phpvboxmgr/config.php
# >> Line 12: var $username = 'vbox'; vbox is the username you created in step 3 above
# >> Line 13: var $password = 'xxx'; where xxx is the password you created in step 3 above
# >> Line 58: var $consoleHost = 'ip.address.of.ReadyNAS'; also <remove> the '#' to activate this feature
# >> Line 175: var $enableAdvancedConfig = true; <remove> the '#' to activate this feature
# >> Line 181: var $startStopConfig = true; <remove> the '#' to activate this feature
## Step 5: Install fsniper to make life even more easier: This is Genius. Pure Genius!
# Fsniper is a directory monitor that can be used to execute predefined actions on files that enter the monitored directory.
# This can, for example, be used to monitor your downloads folder and sort downloaded files automatically into your file system.
# Unlike cron jobs or bash scripts, fsniper uses inotify to monitor file changes.
# This enables it to react immediately and efficiently to changes of the file system.
# Common uses include making a single drop directory and having semi-intelligent scripts figure out what to do with those files.
# More information can be found at the sources below:
# Source 1: weblink>blog.secaserver.com/2011/06/fsniper-monitor-newly-created-files-in-directory/
# Source 2: weblinks>wiki.archlinux.org/index.php/Fsniper
# Source 3: weblink>translate.google.com/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Fwww.ruderwiki.de%2Fwiki_neu%2Findex.php%2FEfa_unter_Linux
# We will use fsniper to automatically make VBox the ower of image files placed in the
# /addons-config/VirtualBox/VirtualMachines/importimage directory and to automatically
# unpack files placed in the VBox backup image directory.
# I place all images from the iNet into the /addons-config/VirtualBox/VirtualMachines/importimage directory.
# For example, I get ClearOS VBox images from weblink>www.clearfoundation.com/Software/downloads.html
# You can also find a plethora of images from weblink>virtualboxes.org/images
# The "sudo sh -c" line creates the fsniper config file. Copy and past all at once into your terminal screen.
# The 'EOF' tells sh to stop reading. You may have to hit <Enter> after you pasted the code to close the file.
# All comments are placed in the fsniper log file: /root/.config/fsniper/log
# fsniper will not notice the file until it is unpacked from the tar/7z/zip/rar container.
# Added Bonus, VDI files are automatically compressed to make them smaller.
# Remember this will be done only once when a *.vdi file is first placed into the directory.
# Compile fsniper
rm -rf fsniper-1.3.1
wget weblink>projects.l3ib.org/fsniper/files/fsniper-1.3.1.tar.gz
tar -xzf fsniper-1.3.1.tar.gz
cd fsniper-*
sudo ./configure
sudo make
# The fsniper binary will be placed in /usr/local/bin
sudo make install
fsniper --version
# Setup the config file
killall fsniper
rm -rf /root/.config
fsniper
killall fsniper
touch /root/.config/fsniper/log
sudo sh -c "cat >> /root/.config/fsniper/config" <<EOF
watch {
# Let's watch My Vbox backup image directory
# Unpacked all storage containers
/addons-config/VirtualBox/backup/images {
recurse = false
# lets monitor based on file ext
*.7z {
handler = echo New 7z %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; 7za e %%
*.bz2 {
handler = echo New bz2 %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; bunzip2 -k %%
*.tar.gz {
handler = echo New tar.gz %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; tar -zxvf %%
*.tgz {
handler = echo New tgz %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; gunzip -c %% | tar -xvf -
*.rar {
handler = echo New rar %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; unrar e %%
*.tar {
handler = echo New tar %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; tar -xf %%
*.zip {
handler = echo New zip %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; unzip %%
# Move unpacked files to the vBox importimage directory
/addons-config/VirtualBox/backup/images/unpacked {
recurse = true
*.ova {
handler = echo Moving OVA %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
*.vdi {
handler = echo Moving VDI %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
*.vmdk {
handler = echo Moving VMDK %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
*.vhd {
handler = echo Moving VHD %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
*.vbox {
handler = echo Moving VBOX %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
*.hdd {
handler = echo Moving HDD %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
# Let's watch the VBox import image directory
# Make sure all images are owned by User VBox in group VBoxUsers
/addons-config/VirtualBox/VirtualMachines/importimage {
recurse = false
*.ova {
handler = echo New IMPORT OVA %% File Detected; chown vbox:vboxusers %%
*.vdi {
handler = echo New IMPORT VDI %% File Detected; chown vbox:vboxusers %%
*.vmdk {
handler = echo New IMPORT VMDK %% File Detected; chown vbox:vboxusers %%
*.vhd {
handler = echo New IMPORT VHD %% File Detected; chown vbox:vboxusers %%
*.vbox {
handler = echo New IMPORT VBOX %% File Detected; chown vbox:vboxusers %%
*.hdd {
handler = echo New IMPORT HDD %% File Detected; chown vbox:vboxusers %%
# Let's watch the VBox export image directory
# Make sure all images are owned by User nobody in group nogroup
recurse = false
*.ova {
handler = echo New IMPORT OVA %% File Detected; chown nobody:nogroup %%
*.vdi {
handler = echo New IMPORT VDI %% File Detected; chown nobody:nogroup %%
*.vmdk {
handler = echo New IMPORT VMDK %% File Detected; chown nobody:nogroup %%
*.vhd {
handler = echo New IMPORT VHD %% File Detected; chown nobody:nogroup %%
*.vbox {
handler = echo New IMPORT VBOX %% File Detected; chown nobody:nogroup %%
*.hdd {
handler = echo New IMPORT HDD %% File Detected; chown nobody:nogroup %%
# Let's watch the VBox working image directory
/addons-config/VirtualBox/VirtualMachines/working {
recurse = true
*.ova {
*.vdi {
*.vmdk {
*.vhd {
*.vbox {
*.hdd {
EOF
# Check to make sure all is well
nano /root/.config/fsniper/config
## Step 6: Install dameontools to make life even more easier
# daemontools is a collection of tools for managing UNIX/Linux services.
# Services created with daemontools will restart automatically if stopped
# Source: weblink>www.bytereef.org/howto/djb/daemontools-install.html
# Source: weblink>cr.yp.to/daemontools.html
rm -rf daemontools
mkdir daemontools && cd daemontools
wget weblink>cr.yp.to/daemontools/daemontools-0.76.tar.gz
wget weblink>smarden.org/pape/djb/manpages/daemontools-0.76-man.tar.gz
wget weblink>www.rickwidmer.com/software/netqmail-1.06.tar.gz
wget weblink>thedjbway.b0llix.net/patches/daemontools-0.76.sigq12.patch
# Install Daemontools:
# supervise, svc, svok, svscan, svscanboot, and svstat into /usr/sbin
tar xzf daemontools-0.76.tar.gz
tar xzf netqmail-1.06.tar.gz
cp netqmail-1.06/other-patches/daemontools-0.76.errno.patch .
cd admin/daemontools-0.76
patch -Np1 -i ../../daemontools-0.76.errno.patch
patch -Np1 -i ../../daemontools-0.76.sigq12.patch
package/compile
cd package
# Finalize svscanboot Setup
sed 's|/command|/usr/sbin|' boot.inittab > boot.inittab~ &&
mv -f boot.inittab~ boot.inittab &&
cd ../command &&
sed -e 's|/command:/usr/local/bin:/usr/local/sbin:||' \
-e 's|/command/svc|/usr/sbin/svc|' svscanboot > svscanboot~ &&
mv -f svscanboot~ svscanboot &&
chmod +x svscanboot &&
/bin/cp * /usr/sbin &&
cd ../package &&
cat /etc/inittab boot.inittab > /etc/inittab~ &&
mv -f /etc/inittab~ /etc/inittab &&
mkdir /service &&
telinit q
# Install Daemontools Man Pages:
apt-get install man
cd /c/addons-config/VirtualBox/backup/daemontools
tar xvzf daemontools-0.76-man.tar.gz
cd daemontools-man
gzip *.8
cp *.8.gz /usr/share/man/man8
# Install fsniper as an automatic service
# Advantage: if stopped, daemontool services automatically restart without using cron or inittab
# If the log file found at /root/.config/fsniper/log is > 2048 bytes, it is deleted and a new one started
killall fsniper supervise svscanboot
cd /
rm -rf /service
mkdir -p /service/fsniper
sudo sh -c "cat >> /service/fsniper/run" <<EOF
#!/bin/sh
export HOME=/root
find ~/.config/fsniper/log -size +2048c -delete
touch ~/.config/fsniper/log
exec /usr/local/bin/fsniper
EOF
chmod 755 /service/fsniper/run
/usr/local/bin/fsniper --daemon
killall fsniper
# Stop fsniper
svc -d /service/fsniper
# Start fsniper
svc -u /service/fsniper
# Test fsniper
ps aux | grep svs && ps aux | grep fsniper && svstat /service/fsniper
reboot
### Section F: Starting the VirtualBox ReadyNAS Server ###
# This is your moment of Happiness not Happyness - Can you name the movie?
# This allows VirtualBox to run as user 'vbox'
ls -ld /opt
# Execute this line again if you ever get the error: "Failed to load VMMR0.r0"
: chown root /opt
# Create VBox Web User ID for VBox Web Server Daemon
: echo "VBOXWEB_USER=vbox" >> /etc/default/virtualbox
: echo "VBOXWEB_HOST=0.0.0.0" >> /etc/default/virtualbox
: echo "VBOXWEB_TIMEOUT=300" >> /etc/default/virtualbox
# Give root Permission to Start the VBox Server as user 'vbox'
: rm -rf /home/vbox
: mkdir -p /home/vbox/.VirtualBox/
: chown vbox:vboxusers /home/vbox
: chown vbox:vboxusers /home/vbox/.VirtualBox
: VBoxManage setproperty websrvauthlibrary default
: login vbox
: VBoxManage setproperty websrvauthlibrary null
: VBoxManage setproperty machinefolder "/c/addons-config/VirtualBox/VirtualMachines"
: exit
## Automatically Start Virtual Machines within VBox
# VBox will start automatically due to daemons vboxdrv and vboxweb-service
# /etc/init.d/vboxdrv loads VBox Kernel drivers into memory
# /etc/init.d/vboxweb-service starts the VBox Web Server
# This step allows VM's that are installed into VBox to start Automatically when your ReadyNAS boots
# NOTE: This is related to Step 4, line 181.
# For this to work, the VM's 'Startup Mode' must be set to 'automatic'
cp /frontview/ui/resource/html/phpvboxmgr/vboxinit /etc/init.d
: chmod u+rx /etc/init.d/vboxinit
: sudo chown root /etc/init.d/vboxinit
update-rc.d vboxinit defaults
# Sample Output:
# >> Adding system startup for /etc/init.d/vboxinit ...
# >> /etc/rc0.d/K20vboxinit -> ../init.d/vboxinit
# >> /etc/rc1.d/K20vboxinit -> ../init.d/vboxinit
# >> /etc/rc6.d/K20vboxinit -> ../init.d/vboxinit
# >> /etc/rc2.d/S20vboxinit -> ../init.d/vboxinit
# >> /etc/rc3.d/S20vboxinit -> ../init.d/vboxinit
# >> /etc/rc4.d/S20vboxinit -> ../init.d/vboxinit
# >> /etc/rc5.d/S20vboxinit -> ../init.d/vboxinit
##*** Start your VBox Engine ***##
# VBox does not use the ReadyNAS Apache Web Server
# The VBox Web Server runs on port 18083.
# It allows you to access the PHP VBox Manager from a web browser
## Start VBox Driver Service ##
: /etc/init.d/vboxdrv restart
## Start VBox Web Server ##
: /etc/init.d/vboxweb-service restart
## Here are some ways to Check on the VBox Web Server that is running on port 18083
netstat -an|grep 18083
# >> # tcp 0 0 127.0.0.1:18083 0.0.0.0:* LISTEN
netstat -lpn | grep 18083
# >> # tcp 0 0 127.0.0.1:18083 0.0.0.0:* LISTEN 17344/vboxwebsrv
# The 17344 represents the PID of the process that owns port 18083
ps axfu | grep 17344
# >> # vbox 17344 0.2 0.2 200476 10476 ? Sl 10:34 0:50 /opt/VirtualBox/vboxwebsrv --background
# We know that VBox's web server was started by /etc/init.d/vboxweb-service start or restart
# However, did you know that it actually issued this command "/opt/VirtualBox/vboxwebsrv --background"
# Easiest way to show VBox Server Info
/etc/init.d/vboxweb-service status
/etc/init.d/vboxdrv status
vboxwebsrv -b
## Start the "Automatically Start Virtual Machines" Service
# Fix corrupted vboxinit
: dos2unix /etc/init.d/vboxinit
: /etc/init.d/vboxinit restart
: chown root /opt
: apt-get -f install && apt-get update
## [Reboot] ReadyNAS
reboot
## NOW: Access VirtualBox Manager from: weblink>IP_of_your_ReadyNAS_Box/phpvboxmgr
# 1. Login as User 'admin' using the PHP VirtualBox Manager with an ID/PW of admin/admin
# 2. GOTO: [File] -> [Preferences] -> [Users] to add User 'vbox' as an (Admin User)
# 3. Logout and log back in as User 'vbox'
# 4. [Delete] User 'admin'
# Now that you are logged in as User 'vbox', deactivate the login security dialog box
# >> Line 55: var $noAuth = true; <remove> the '#' to activate this feature which removes login requirements
# If you installed fsniper, check to make sure it is running
ps -ef | grep svscan && ps -ef | grep supervise
# Sample Output:
#root 3495 1 0 19:24 ? 00:00:00 /bin/sh /usr/sbin/svscanboot
#root 3497 3495 0 19:24 ? 00:00:00 svscan /service
#root 3499 3497 0 19:24 ? 00:00:00 supervise fsniper
## Change the default VirtualMachine folder of VBox
# First, from the command line:
: login vbox
: VBoxManage setproperty machinefolder "/c/addons-config/VirtualBox/VirtualMachines/working"
: exit
# Second, using phpVBoxManager:
: Access: weblink>IP_of_your_ReadyNAS_Box/phpvboxmgr/
: Check this just to be sure: [Preferences] -> [General] -> [Default Machine Folder]: /c/addons-config/VirtualBox/VirtualMachines/working
# If everything worked, you should have a smile on your face:)
# VBox will start automaticall when you boot.
# You can also manually start the VBox Web Server using '/opt/VirtualBox/vboxwebsrv'
# I run it this way to trouble-shoot vbox permission issues.
## Example: How to create a Ubuntu VM from the command line
# Stats: Ubuntu 13.04 (Raring Ringtail) Server with 512MB memory and a 10GB hard drive from the Ubuntu Server iso image
# REF: weblink>releases.ubuntu.com/
# If you are interested in the Ubuntu Edge Cell Phone kickstarter, goto: weblink>igg.me/at/ubuntuedge/x/4048109
wget weblink>releases.ubuntu.com/raring/ubuntu-13.04-desktop-amd64.iso
wget weblink>releases.ubuntu.com/raring/ubuntu-13.04-server-amd64.iso
# NOTE: When using VBoxManage from the command line, you must do it as user vbox
# If you do not create the VM as user vbox, it will be "invisible" and cannot be controlled by phpVBoxManager
# If you create VM's using phpVBoxManager, you are automatically doing it as user vbox.
login vbox
VBoxManage createvm --name "Ubuntu 13.04 Server" --ostype "Ubuntu_64" --register
VBoxManage modifyvm "Ubuntu 13.04 Server" --memory 512 --vram 12 --ioapic on --boot1 dvd --boot2 disk --boot3 none --boot4 none
VBoxManage modifyvm "Ubuntu 13.04 Server" --nic1 bridged --bridgeadapter1 eth0
VBoxManage createhd --filename "/c/addons-config/VirtualBox/VirtualMachines/working/Ubuntu 13.04 Server/Ubuntu_13_04_Server.vdi" --size 10000
VBoxManage storagectl "Ubuntu 13.04 Server" --name "IDE Controller" --add ide
VBoxManage storageattach "Ubuntu 13.04 Server" --storagectl "IDE Controller" --port 0 --device 0 --type dvddrive --medium /addons-config/VirtualBox/backup/images/ubuntu-13.04-server-amd64.iso
VBoxManage storagectl "Ubuntu 13.04 Server" --name "SATA Controller" --add sata --controller IntelAHCI
VBoxManage storageattach "Ubuntu 13.04 Server" --storagectl "SATA Controller" --port 0 --device 0 --type hdd --medium "/c/addons-config/VirtualBox/VirtualMachines/working/Ubuntu 13.04 Server/Ubuntu_13_04_Server.vdi"
exit
# Did you know that you can assign an iSCSI device as the attached VM Storage?
# REF1: weblink>scarygliders.net/2011/11/04/virtualbox-and-iscsi-nas-how-to-linux-windows
# REF2: weblink>www.thecus.com/download/howtoguide/HowtoConnecttoaniSCSITargetUsingWindows.pdf
Virtual Machine Ideas:
1. ClearOS Firewall (Great due to 2x Ethernet ports: weblink>www.clearcenter.com/Software/clearos-professional-downloads.html)
> although written for IPCop in a VM, this related discussion may help with ip/port setup and configuration ( weblink>greenpossum.awardspace.com/ipcop-in-vbox.html)
2. Music Brainz Server: weblink>musicbrainz.org/doc/MusicBrainz_Server/Setup
> Network Settings:Bridged Adapter, eth0, Intel PRO/1000 MT Desktop
> username: musicbrainz password: musicbrainz
> sudo ~/run_replication.sh
> ifconfig | grep eth0 -A 1
> ~/run_server.sh
> Access: weblink>current.ReadyNAS.ip.address:5000
3. Kolab Server 3.0 via CentOS VM: weblink>bmts.us/wiki/doku.php?id=article:kolab:centos && weblink>kolab.org/get-kolab
4. Android 4.x:
a. weblink>www.androidjuegosfull.com/how-to-install-android-in-virtualbox/aplicaciones-android
b. weblink>www.maketecheasier.com/run-android-4-3-in-virtualbox/2013/08/02?utm_source=facebook
5. ChromimumOS (weblink>chromeos.hexxeh.net/)
> Instructions @ weblink>www.androidauthority.com/howto-test-drive-chrome-os-features-the-chromium-way-155084/
6. Amahi Server 7, Ubuntu 12.04 (weblink>www.amahi.org/)
> for Ubuntu 12.04 build a VM (weblink>blog.coolaj86.com/articles/how-to-install-ubuntu-in-virtualbox.html)
> and follow this process (weblink>docs.amahi.org/ubuntu-12.html)
7. Synology DSM 4.1 (weblink>xpenology.com/forum/viewtopic.php?f=2&t=3&sid=c766ced785bd2610629e8b24bddd3d45)
8. Windows 8 (weblink>www.youtube.com/watch?v=u5rk4E-5yVU)
End of Mission!
### VBox: 4.3.2
Python [2.7.6]
Php5 [5.4.21]
phpMyAdmin [4.0.9]
### with new users.
### Thanks
### KEY NOTES:
sudo -s -H
apt-get clean
apt-get clean
EOF
apt-get update
sudo visudo
# Update Logger
find / -name logger
cd /usr/bin
ls -aFl logg*
nano logger
#!/bin/bash
do
case ${Option} in
esac
done
chmod +x logger
apt-cache policy
apt-get install \
amd64-libs \
binutils \
bison \
build-essential \
dialog \
fakeroot \
flex \
gdb \
gpp \
kernel-package \
lib64ssp0 \
lib64stdc++6 \
libbz2-dev \
libc6-amd64 \
libc6-dev-amd64 \
libdb3-dev \
libgdbm-dev \
libncurses5-dev \
libpcre3-dev \
libsqlite3-dev \
libssl-dev \
libtag1-dev \
libtool \
p7zip \
p7zip-full \
par2 \
parchive \
uuid-dev \
zlib1g-dev \
zlibc
ldconfig -v
cd file-5.14
./configure
cp *.deb ..
ldconfig
file --version
cd xz-5.0.5
./configure
cp *.deb ..
apt-cache policy xz
ldconfig
xz --version
cd gzip-1.6
./configure
cp *.deb ..
gzip --version
gunzip --version
gzexe --version
./configure
cp *.deb ..
fuseiso -h
fusermount -V
cd ccd2iso-0.3
./configure
cp *.deb ..
ccd2iso --help
extlinux --help
#!/bin/bash
# version: 1.0
echo ""
if [[ $# -ne 2 ]]
then
echo ""
exit 1
fi
echo ""
cd $1
for file in $1/*
do
then
then
else
fi
else
fi
echo ""
done
echo ""
echo ""
ls /usr/local/bin
ls /bin/*.bak
ls /usr/bin/*.bak
apt-cache policy
Pin-Priority: 1001
Package: noflushd
Pin-Priority: 1001
apt-get -f install
rm -rf Python*
cd Python-2.7.6
./configure
cp *.deb ..
python -V
rm -rf setuptools*
pip install -U pip
file --version
pip install ipython
pip install numpy
binwalk --help
tar xfz files.tgz
unrar
undvd
apt-get install \
apache-dev \
automake \
byacc \
libbz2-dev \
libmcrypt-dev \
libmcrypt4 \
libonig2 \
libqdbm14 \
libreadline5-dev \
libxslt1-dev \
libxslt1.1 \
libzzip-0-12 \
lsof \
re2c
ldconfig -v
rm -rf php5*
apt-get source php5
cd php5-5*
cd pear
cd ..
find / -name apxs*
updatedb
./configure \
--enable-mbstring \
--enable-soap \
--enable-zip \
--with-bz2 \
--with-gettext \
--with-mcrypt \
--with-mhash \
--with-mysql \
--with-mysqli \
--with-readline \
--with-zlib
cd ..
cd /etc/php5/bin
# Show PHP5 version
php -v
#!/bin/bash
MYCHECK_RCPT="root"
) >&2 &
exit 0
# Reboot NAS
reboot
# Who owns Apache?
<?php
phpinfo();
EOF
# Restart Apache
killall apache-ssl
--basedir=/usr \
--skip-locking \
#apt-get update
apt-get install \
libmcrypt4 \
rm -rf phpMyAdmin-*
ls -aFl
cd phpmyadmin
mkdir config
chmod o+rw config
# Restart Apache
killall apache-ssl
--basedir=/usr \
--skip-locking \
mysql -uroot -p
mysql> \q
## <save>
## <save>
## Move Config File
rm -rf config
# Restart Apache
killall apache-ssl
--basedir=/usr \
--skip-locking \
## Test phpMyAdmin
## Username: root
## Password:(empty)
## <GO>
df && df -i
cd /root
rm -rf /root/*
apt-get update
rm -rf kernel
mv kernel ..
rm -rf build
rm -rf source
: make prepare
## Start the Build!
: make
: rm -rf /etc/vbox
: rm -rf /home/vbox
: modprobe -l
: dmesg | grep vbox
ls -ld /opt
: chown root /opt
make
ls -aFl
uname -r
### End Test
addgroup vboxusers
# Room Number []:
# Work Phone []:
# Home Phone []:
# Other []:
# [Apply]
# Compile fsniper
cd fsniper-*
sudo ./configure
sudo make
sudo make install
fsniper --version
killall fsniper
fsniper
killall fsniper
watch {
recurse = false
*.7z {
*.bz2 {
*.tar.gz {
*.tgz {
*.rar {
*.tar {
*.zip {
recurse = true
*.ova {
*.vdi {
*.vmdk {
*.vhd {
*.vbox {
*.hdd {
recurse = false
*.ova {
*.vdi {
*.vmdk {
*.vhd {
*.vbox {
*.hdd {
recurse = false
*.ova {
*.vdi {
*.vmdk {
*.vhd {
*.vbox {
*.hdd {
recurse = true
*.ova {
*.vdi {
*.vmdk {
*.vhd {
*.vbox {
*.hdd {
EOF
rm -rf daemontools
package/compile
cd package
cd ../command &&
cd ../package &&
mkdir /service &&
telinit q
apt-get install man
cd daemontools-man
gzip *.8
cd /
rm -rf /service
#!/bin/sh
export HOME=/root
EOF
killall fsniper
# Stop fsniper
# Start fsniper
# Test fsniper
reboot
ls -ld /opt
: chown root /opt
: rm -rf /home/vbox
: login vbox
: exit
# Sample Output:
vboxwebsrv -b
: chown root /opt
reboot
# Sample Output:
: login vbox
: exit
login vbox
exit
> ~/run_server.sh
4. Android 4.x:
End of Mission!
