ErnieAlex
May 05, 2019Aspirant
Web Server does not work correctly. CSRFP-ID errors
I have the 80 Terrabyte NAS unit. (Not all drives in place.) I have one folder set up as a web server. But, my pages do not seem to render correctly. I keep getting extra code placed into the page when viewed on all of the browser I have tested it on. Also, Javascript and JQuery do not work either.
Hope someone can tell me what to do to fix this.
Further Info:
Some tests show that any webpage fails and just before the </head> tag, this line appears:
<script language="JavaScript" src="/csrf.js?i=0504" type="text/javascript"></script>
Also, just before the </body> tag, these lines are inserted:
<script type="text/javascript"> <!-- csrfInsert("csrfpId", "t-token-key-removed here-M="); //--> </script>
For some reason the unit is not showing the code I put in the page, but, adds the above lines. I do not know what "csrfpID" is stuck in the response from the server. Can a tech please reseach this and tell us how to fix this token issue? Thanks for any help with this!
Message 2 of 3
- ErnieAlexAspirant
The other post I did under another topic does not let me reply to it. Therefore, I will stick to this post.
The system is a ReadyNas 628X. It has the latest OS on it which was recently updated. Version OS6.10.0
Since this update, I have not been able to view webpages from a folder on the unit. It keeps throwing out CSRFP-ID errors.
A bare HTML file with nothing except a <hmtl><header><body> tags and some simple text will throw out these CSRFP errors.
It appears there is a flaw in the OS6.10.0 update. I spent thousands of dollars on this unit to be able to serve files through my local lan.
And, it does not even display simple pages.
Can anyone help me with this issue? I can not reset the unit to it's original values since I have it nearly full of files...
- ErnieAlexAspirant
94 views and nobody has a solution? Does anyone have this same issue?
- ErnieAlexAspirant
Thousands of dollars and this thing can't serve PHP out to my other local computers.... Silly waste of money!
164 views and not one response... Oh, well, will just have to sell off this unit and set up a real server here...
