Rarasmus
May 25, 2021Aspirant
What is Accessing My RN10200 Hard Drives?
The hard drives in my RN10200 seem to be running very often. I use the RN10200 to back up my PC. I can hear the drives being accessed often throughout the day. I have confirmed that it is not my sche...
- May 26, 2021
Rarasmus wrote:
What do you make uf this? Disks are spinning up and down multiple times each hour.
Looks like 6 spinups in 140 minutes. Though 5 had a short spindown duration. I've seen similar stuff, the question is what is triggering the activity. There's not an easy way to tell from the logs.
But disk 1 is spinning more minutes than disk 2 (generally spinning up before disk 2). The system boots off of disk 1 normally, so that does suggest the OS is doing something.
One test you can do is to disconnect the NAS from the network when you aren't using it, and see if that calms the spinups.
Rarasmus
May 26, 2021Aspirant
May 26 09:06:47 RandysNAS noflushd[4776]: Spinning up disk 1 (/dev/sda) after 0:32:54.
May 26 09:06:57 RandysNAS noflushd[4776]: Spinning up disk 2 (/dev/sdb) after 1:01:21.
May 26 09:58:13 RandysNAS noflushd[4776]: Spinning down disk 2 (/dev/sdb).
May 26 09:58:20 RandysNAS noflushd[4776]: Spindown of disk 2 (/dev/sdb) cancelled.
May 26 10:05:01 RandysNAS noflushd[4776]: Spinning down disk 2 (/dev/sdb).
May 26 10:10:10 RandysNAS noflushd[4776]: Spinning down disk 1 (/dev/sda).
May 26 10:17:08 RandysNAS noflushd[4776]: Spinning up disk 2 (/dev/sdb) after 0:12:04.
May 26 10:17:13 RandysNAS noflushd[4776]: Spinning up disk 1 (/dev/sda) after 0:07:01.
May 26 10:22:14 RandysNAS noflushd[4776]: Spinning down disk 1 (/dev/sda).
May 26 10:22:17 RandysNAS noflushd[4776]: Spinning down disk 2 (/dev/sdb).
May 26 10:30:06 RandysNAS noflushd[4776]: Spinning up disk 1 (/dev/sda) after 0:07:49.
May 26 10:30:06 RandysNAS noflushd[4776]: Spinning up disk 2 (/dev/sdb) after 0:07:46.
May 26 10:35:06 RandysNAS noflushd[4776]: Spinning down disk 2 (/dev/sdb).
May 26 10:39:20 RandysNAS noflushd[4776]: Spinning down disk 1 (/dev/sda).
May 26 10:42:48 RandysNAS noflushd[4776]: Spinning up disk 1 (/dev/sda) after 0:03:25.
May 26 10:42:58 RandysNAS noflushd[4776]: Spinning up disk 2 (/dev/sdb) after 0:07:49.
May 26 10:59:10 RandysNAS noflushd[4776]: Spinning down disk 1 (/dev/sda).
May 26 10:59:14 RandysNAS noflushd[4776]: Spindown of disk 1 (/dev/sda) cancelled.
May 26 11:08:26 RandysNAS noflushd[4776]: Spinning down disk 1 (/dev/sda).
May 26 11:08:29 RandysNAS noflushd[4776]: Spinning down disk 2 (/dev/sdb).
May 26 11:09:52 RandysNAS noflushd[4776]: Spinning up disk 1 (/dev/sda) after 0:01:23.
May 26 11:09:52 RandysNAS noflushd[4776]: Spinning up disk 2 (/dev/sdb) after 0:01:21.
May 26 11:15:23 RandysNAS noflushd[4776]: Spinning down disk 1 (/dev/sda).
May 26 11:15:26 RandysNAS noflushd[4776]: Spinning down disk 2 (/dev/sdb).
May 26 11:17:14 RandysNAS noflushd[4776]: Spinning up disk 1 (/dev/sda) after 0:01:48.
May 26 11:17:19 RandysNAS noflushd[4776]: Spinning up disk 2 (/dev/sdb) after 0:01:51.
May 26 11:26:30 RandysNAS noflushd[4776]: Spinning down disk 1 (/dev/sda).
May 26 11:26:33 RandysNAS noflushd[4776]: Spinning down disk 2 (/dev/sdb).
May 26, 2021Guru - Experienced User
