BulletRouge
Feb 10, 2018Aspirant
Where is 'make' ??
Running current system 6. I wanted to install a DynamicDNS client, which needs make to build/install. But I can't find it on my system! Gotta be there somewhere right?
Feb 10, 2018Guru - Experienced User
No, you'll need to install it.
BulletRouge
Aw!
Sorry, but how do I install it?
- StephenBFeb 10, 2018Guru - Experienced User
I think what you need to install is build-essential (as you will need more than make).
You can try entering apt-get install build-essential and see if that works - though there might be more to it than that.
- BulletRougeFeb 10, 2018Aspirant
Worked! Thanks!
I'm glad we could help.
