ranchracer
Dec 11, 2016Aspirant
Wireless, battery powered cameras with RN Surveillance App?
Just curious if anyone has had any luck using any of the wireless, battery powered cameras readily available at the big box stores with the RN Surveillance app? I think Netgear is missing a sizeable ...
Dec 11, 2016Guru - Experienced User
ranchracer wrote:
I think Netgear is missing a sizeable chunk of the market by not certifying the Arlo cameras for the app. What about other brands?
I haven't purchased RN Surveillance, but wanted to add that IMO Alro cameras should be supported in ReadyNAS without needing to purchase Surveilance.
Certainly if you do purchase Surveillance it should work with Netgear cameras.
- Nov 24, 2016Retired_Member
