Kalle13
Oct 13, 2019Tutor
- can' t backup remotely through ssh and rsync
Hello, I would like to backup some files from a Debian Computer via ssh and rsync. My firmware version is 6.10.1. When I am configuring my remote backup I choose on the left side "remote" and on...
Oct 13, 2019Guru - Experienced User
What IP address are you using for the remote source?
Have you tried doing this with rsync (not rsync over ssh)?
Kalle13
Oct 13, 2019Tutor
Hi Steven,
It' s an IP from my LAN range: 192.168.178.*
No, because I have not configured rsync as a server.
- StephenBOct 13, 2019Guru - Experienced User
Main question here was whether it was the IP of the debian pc.
Kalle13 wrote:> Have you tried doing this with rsync (not rsync over ssh)?
??? It needs to be configured as a server on the debian machine in order for this to work.
- Kalle13Oct 13, 2019Tutor
Yes, it was.
> ??? It needs to be configured as a server on the debian machine in order for this to work.Sure? Here somebody says that if you have a correct verified ssh connection you only need rsync to be installed. Nothing more.
My ssh connection via keys works fine.- StephenBOct 13, 2019Guru - Experienced User
My ssh connection via keys works fine.I'm not seeing that in your link, though maybe I am missing it.
rsync is a client-server protocol, and the NAS backup jobs are rsync clients. The remote system needs to be set up as an rsync server.
If the remote system were another ReadyNAS, that would be done by enabling rsync as a protocol for the share.
