cyse
Jan 09, 2012Aspirant
1 disk with data to second RAID1
Hi everybody, I have a netgear ultra4 and received two hard disks with it but one of them was broken and i returned it to the seller, waiting for the new one. I put one disk inside the no1 slot ...
TeknoJnky
Jan 09, 2012Hero
If you setup the nas with the default x-raid mode (check frontview > volumes), then yes it should be simply:
carefully insert disk 2
nas will do short test disk
format and mirror (resync) from disk 1 to disk 2
note however, nas is not designed to continue to add/remove disk 2 for use as 'backup'.
if you want to backup your data, you should use an external usb drive.
