cyse
Jan 09, 2012Aspirant
1 disk with data to second RAID1
Hi everybody, I have a netgear ultra4 and received two hard disks with it but one of them was broken and i returned it to the seller, waiting for the new one. I put one disk inside the no1 slot ...
Jan 10, 2012Guru - Experienced User
Hi cyse
If you are wanting to install a replacement disk for the one that was broken, then you just follow TeknoJnky's instructions.
When you get the new one from the seller, you can either install it also (getting more capacity) or keep it for a spare.
