cyse
Jan 09, 2012Aspirant
1 disk with data to second RAID1
Hi everybody, I have a netgear ultra4 and received two hard disks with it but one of them was broken and i returned it to the seller, waiting for the new one. I put one disk inside the no1 slot ...
Jan 10, 2012Guru - Experienced User
You can see the smart statistics for each drive from Frontview. Also if you have email notifications turned on, you will get email alerts when reallocated sectors (and some other stats) change.
You are correct that it is easiest to back up your NAS to another NAS.
