cyse
Jan 09, 2012Aspirant
1 disk with data to second RAID1
Hi everybody, I have a netgear ultra4 and received two hard disks with it but one of them was broken and i returned it to the seller, waiting for the new one. I put one disk inside the no1 slot ...
PapaBear1
Jan 11, 2012Apprentice
If you have the alerts set to send you an e-mail, anytime a significant change in the SMART logs for each drive occurs, it will send you an e-mail. I currently have a 1TB drive (18 months old) that is starting to throw ATA errors. It will go days or weeks and then throw about 3 to 6 ATA errors (count is currently 278) and each time there is an increase, I get an e-mail from my NAS1.
It will not notify you of normal items that are considered routine, but will notify you of any errors or warnings so you can be prepared. However, there can be sudden failures such as an electrical failure in the drive electronics or a serious mechanical malfunction in the drive where it just stops functioning. You will then get a message about a drive failure.
