FerociousNAS
Mar 15, 2025Tutor
1002030001 Commit failed when creating a new folder
Fresh setup. When I create a new folder I get "1002030001 Commit failed" (see pic). I refresh the WebUI and the folder is created and usable. I get the same error when I delete the folder. Any sugges...
- Mar 16, 2025
FerociousNAS wrote:
Thank you, log sent.
As I said in my PM, the error is coming from the NAS iTunes server. If you don't need that service, then I suggest just turning it off.
Mar 16, 2025Guru - Experienced User
FerociousNAS wrote:
Fresh setup. When I create a new folder I get "1002030001 Commit failed" (see pic). I refresh the WebUI and the folder is created and usable. I get the same error when I delete the folder. Any suggestions? Thx in adv.
ReadyNAS 422
FW: 6.10.9
RAID 1
4GB x 2 Iron Wolf HDD
HDD Encryption
X-Raid: No
Are you creating a share?
I am wondering if the OS partition is full. Try downloading the full log zip file from the logs page. There is a lot of information in there.
If there is no data on the NAS yet, you can also try "perform factory default" on system->settings->update. That will reformat the disks and do a fresh factory install.
Sandshark
Mar 16, 2025Sensei
Check the OS partition use first, as StephenB recommended. If that's not the problem, I'm wondering if it's a problem with the configuration of one particular protocol or snapshots. Try creating a share and deselect all protocols and no snapshots and see if you still get the error. If not, try to figure out which protocol is creating the error through process of elimination.
