FerociousNAS
Mar 15, 2025Tutor
1002030001 Commit failed when creating a new folder
Fresh setup. When I create a new folder I get "1002030001 Commit failed" (see pic). I refresh the WebUI and the folder is created and usable. I get the same error when I delete the folder. Any sugges...
- Mar 16, 2025
FerociousNAS wrote:
Thank you, log sent.
As I said in my PM, the error is coming from the NAS iTunes server. If you don't need that service, then I suggest just turning it off.
Mar 16, 2025Guru - Experienced User
FerociousNAS wrote:
-Strange cause the RN HDDs were synced. I pulled the LOG file but can't upload the Zip. Is there and specific file I can attach as a PDF from the log to see what was going on?
It's best not to post it publicly.
If you'd like me to take a look, then upload the zip to cloud storage (dropbox, google drive, etc) and send me a PM (private message) with a link to the zip. Make sure the permissions allow anyone with the link to download. You send the PM using the envelope icon in the upper right of the forum page.
FerociousNAS
Mar 16, 2025Tutor
đź¤
- StephenBMar 16, 2025Guru - Experienced User
- FerociousNASMar 16, 2025Tutor
Thank you so much. Not using and will shut it down. What would that cause the issue?
- StephenBMar 17, 2025Guru - Experienced User
The error sequence is
Mar 15 20:52:22 nas-44-82-A2 readynasd[4386]: Failed to create daap apps cache dir. rc = 1 Mar 15 20:52:22 nas-44-82-A2 readynasd[4386]: rndb_daap_service_export() ==> 1 (0ms) Mar 15 20:52:22 nas-44-82-A2 readynasd[4386]: rndb_export() ==> 1 (104ms) Mar 15 20:52:22 nas-44-82-A2 readynasd[4386]: share.c:963:process_add_share Failed to commit_dba. category = 3, ret_val = 1 Mar 15 20:52:22 nas-44-82-A2 readynasd[4386]: Error in commitdba status=1The daap service is the iTunes server. What I can't see is why it couldn't create the cache directory. As I mentioned in the PM, this might be a bug triggered by your use of volume encryption.
I think the "commit_dba" error is a consequence of the daap apps error. Though it is possible that something else was happening, the place to start is to just turn off iTunes. (General advice is to only enable services that you use).
