rit1
Jan 18, 2014Aspirant
104 support for Rsync over SSH
It looks like at least in the 10x Readynas 6.0 software release there is no easy way to set things up so that a remove device (such as my Andriod phone) can use Rsync over SSH to backup to a 104 target. Can we please have this feature added/re-instated.
What seems to be missing is for the GUI to support the adding of SSH public keys to the network access panel. Currently all you can do is add a password to a user, but you can't provide a valid public key.
1 Reply
- ClaesBasAspirantIf you knew how to do Rsync over SSH, then you knew how to enable SSH (and your public key) on your device (with SSH and CLI)... or?
(If not, then I could help you! Hint: Enable SSH and do a SSH login...)
