fragglerok
Nov 19, 2015Aspirant
104 to 214
is it possible to take disks from a 104 and put them in a 214 without data loss ?
fragglerok
is it the same on a 314 ? ( price differential at the moment is minimal)
Nov 19, 2015Guru - Experienced User
Even though the RN314 uses an x86 processor, it is supposed to be the same.
I'd go with the RN314 if the price difference is small. Lifetime software chat support vs 90 days with the ARM products. Though check the warranty registration posts - you do need to be careful about the reseller you use. The lifetime CHAT support is only for brand new and sealed products purchased from authorized resellers.
