SCUBAInstructor
Dec 17, 2019Guide
10Gbps PCi express card
Hi I would like to upgrade my RN516 and install a 10Gpbs Intel X540-T2 in my chassis. Looks like there is pci express riser card needed. Is it possible to use an OTS version or is it Netgear specif...
Marc_V
Dec 17, 2019NETGEAR Employee Retired
Welcome to Community!
NETGEAR does not have an available card that will fit currently and it is still not supported. You may be able to find a card that can be used with the slot but again it may need modification which will void the warranty and since it is not yet supported the chances of it working with the NAS is not guaranteed.
HTH
Regards
