SCUBAInstructor
Dec 17, 2019Guide
10Gbps PCi express card
Hi I would like to upgrade my RN516 and install a 10Gpbs Intel X540-T2 in my chassis. Looks like there is pci express riser card needed. Is it possible to use an OTS version or is it Netgear specif...
Sandshark
Dec 17, 2019Sensei
You can probably find a flexible cable extender that will make that card work, but supporting it is a problem not as easily solved.
- SCUBAInstructorDec 17, 2019Guide
Hi Sandshark
I have found this: netgear_readynas716_board.jpg
The only difference between RN516 and RN716 (other than cpu and memory) is the 10Gbps card. I bought a used model of the card visible in that picture. ReadyNAS should support it, shouldn't it?
- SandsharkDec 17, 2019Sensei
I believe it will. The 4220 uses a similar card, and I moved one to a 4200V2 converted to OS6 and it was recognized. I didn't have a way to actually use it, but the OS just showed it like it belonged. There certainly aren't different versions of the kernel compiled for units with and without, so the driver is going to be there.
