carpii
Mar 31, 2020Tutor
1U rack mount ReadyNAS, are they all end of life?
I have 3 aging ReadyNAS right now (2 ReadyNAS Pro 4, and a ReadyNAS NVX) A drive has just failed yet again on one of the Pro 4's, but I'm now having trouble sourcing replacement drives which are on ...
- Apr 01, 2020
UPDATE
RN3138 was a year earlier than the RR2304. RN3138 is actually not EOL, the disclaimer was removed upon inquiry. Though the service note should still be checked specially if you have already purchased one.
https://kb.netgear.com/000037344/Service-Note-for-RN3130-RN3138-WC7500-and-WC7600v2
So RN3138 is still available and will not be on EOL soon.
HTH
Regards
HTH
Sandshark
Apr 01, 2020Sensei
I suspect sales figures also had something to do with it. It may be that few wanted the higher spec units with only 4 bays.
But it is quite concerning that Netgear hides the fact that this NAS is end of life when it still continues to be sold. It is still listed as a viable alternative on https://www.netgear.com/business/products/storage/readynas/readynas-rackmount.aspx#tab-models and only by selecting that model and then selecting "Tech Specs" and then "Get Support" does one find it is EoL. Everything prior to that fails to give this very important information.
Apr 01, 2020Guru - Experienced User
While I get the need to sell off the inventory in the channels, I agree this information shouldn't be so hidden. It's led to speculation here about EOL status of other models more than once.
I think this likely does explain the drop in price of the 3138 a few months back.
