engine411
Aug 07, 2013Aspirant
2100 and SSD's
Several years ago, using SSD's in RAID was not recommended because the RAID controllers tended not to support TRIM and garbage collection on the SSD's. What is the current advice for using SSD's in a ...
mdgm-ntgr
Aug 07, 2013NETGEAR Employee Retired
Well SSDs are not supported in RAIDiator 4.2.x but some are for ReadyNAS OS devices. You can run 6.0.x on the 2100 v2 (but not the v1) though it is unsupported. See http://www.readynas.com/forum/viewtopic.php?f=35&t=70323
Even if you update to the new OS you still have the issue that SSDs tend to be 2.5" and the drive trays in the 2100 v2 are 3.5"
