engine411
Aug 07, 2013Aspirant
2100 and SSD's
Several years ago, using SSD's in RAID was not recommended because the RAID controllers tended not to support TRIM and garbage collection on the SSD's. What is the current advice for using SSD's in a ...
engine411
Aug 08, 2013Aspirant
Thank you.
Does anyone have a good estimate of the relative throughput of two teamed gigabit NIC's versus the four 7200 rpm SATA drives in XRAID2? Which can move more data? Meaning, can reading data from the drives saturate the NICs capacity assuming all other factors in the network can handle this amount of data? Or do the LACP teamed NIC's still have headroom when the drives are maxed out in read throughput?
