engine411
Aug 07, 2013Aspirant
2100 and SSD's
Several years ago, using SSD's in RAID was not recommended because the RAID controllers tended not to support TRIM and garbage collection on the SSD's. What is the current advice for using SSD's in a ...
mdgm-ntgr
Aug 08, 2013NETGEAR Employee Retired
I don't think with hard drives teaming the NICs would do much if anything to improve performance. One would think using SSDs would make some difference to performance but as only running 4.2.x on the 2100 is supported and 4.2.x does not support SSDs there aren't any performance numbers out there to show the difference between using SSDs and HDDs as far as I'm aware.
