engine411
Aug 07, 2013Aspirant
2100 and SSD's
Several years ago, using SSD's in RAID was not recommended because the RAID controllers tended not to support TRIM and garbage collection on the SSD's. What is the current advice for using SSD's in a ...
mdgm-ntgr
Aug 08, 2013NETGEAR Employee Retired
The 2100 v2 Performance would be similar to that of the Pro 4 (as they both use the same CPU): http://www.readynas.com/?page_id=5410
You can see that a single NIC is pretty much maxed out for writes, but not for reads. I think there would be some performance benefit from using SSDs when using teaming but you could test it out for yourself.
