engine411
Aug 07, 2013Aspirant
2100 and SSD's
Several years ago, using SSD's in RAID was not recommended because the RAID controllers tended not to support TRIM and garbage collection on the SSD's. What is the current advice for using SSD's in a ...
engine411
Aug 08, 2013Aspirant
For small files, directory browsing/searching, database updates (other non-sequential access), then SSDs should make a huge difference since they have no latency when seeking. That would be your IOPS / throughput distinction. If you want to maximize IOPS, then SSDs are what you want (assuming you can afford them).
This is our use scenario. I will research this further. Thanks.
