nitro001
Sep 09, 2012Aspirant
3 of 4 ST31000528AS Drives doing bad in NV+ ?
All, I have an NV+ Running 4 Seagate ST31000528AS Drives, giving me 2743 GB in a X-RAID setup. And currently using 1808 GB of it. One of the drives (Disk 1) had a growing re-allocation sector size...
nitro001
Sep 10, 2012Aspirant
@StephenB,
Thank you, I am currently out of town, but will check this weekend. Have not received any email warnings yet about any further drive issues.
@PapaBear,
i was wondering if I was overwhelming the system, when the RSYNC started, the cpu seemed ok, which is why I left it alone, but disks were probably thrashing.
I believe it has copied my wifes most important stuff over already with the RSYNC before it died :). So looks like I need to finish it up via Windows File Copy through a remote machine to slow it down a bit. I think I have a directory sync tool that I can use with a couple mounted SMB Drives. Afterwards though, you think the RSYNC will work, once I have all the data over there.
Thanks,
Nathan
@PapaBear,
Thanks,
Nathan
