real_neo
Dec 19, 2011Aspirant
3TB HDDs for ReadyNas 2100?
Hello, any recommendation for 3TB HDDs? As I understand, the most important issues are low power consumption and hight MTBF, isn't? Therefore what drive will more suitable: - WD AV-GP WD30EURS ...
mdgm-ntgr
Dec 19, 2011NETGEAR Employee Retired
Please stick to the compatibility list. If you use a drive not on the list you will be denied support if you have problems.
There are other brands you can look at like Hitachi which is a popular choice in recent times
The slowest disk is going to limit performance, but it shouldn't make too much of a difference.
