falconyt's avatar
falconyt
4 pin din power supply replacement for RN104
Hello,   Recently picked up a used ReadyNAS RN104, the power supply adapter that has come with it doesn't stay in the ReadyNAS unless you really push it in. The ReadyNAS works fine however, I would...
  • BrianL2's avatar
    Dec 20, 2015
    Hi falconyt,
    Yes, a similar power supply with the same specs would do it. Pins or connector differ where the product was released or being sold.
    Kind regards,
    BrianL
    NETGEAR Community Team
ProSupport for Business
