dunkens
Dec 29, 2019Apprentice
405 method not allowed readynas 526
Hi Trying to access the readynas shared folder via cyberduck alt netdrive , but it ends up with 405 method not allowed Trying to mount a local drive via network path Is there some special...
Dec 29, 2019Guru - Experienced User
Are you doing this remotely (over the internet) or locally?
I have no experience with either tool, but it looks like you'd need to use FTP or WebDav with Cyberduck. Either way, you would need to enable the protocol for the NAS share, and you'd need port forwarding set up in your router to use either protocol remotely.
- dunkensDec 29, 2019Apprentice
Hi
Its locally.
Port 443 is open
WebDav is enabled in the share aswell
Any other idea why webdav aint working ?
