MightyGorilla
Feb 12, 2013Aspirant
4200 - One drive "ignored"
We have a second-hand 4200 V1 that I've just filled with 2TB disks that are on the HCL. Turning on the unit, all the drives have the red led glowing, and then after that goes out, and each drive spin...
ReadySECURE
Feb 12, 2013Apprentice
I would like to say it isn't common that just 1 port is bad. Generally, we recommend that you attempt to do what you have already done (as in take off the lid and attempt to stabilize the cables, making sure that they are pushed in 100% on the questionable bay).
You could, in turn, purchase a contract for your second-hand 4200 and have it replaced under contract and should have no problems with that. Contact Support in relation to PMB0334NA, OnCall 24x7 Category 4.
