fondy
Apr 13, 2012Tutor
4k sector ?
Hi, I am new to readynas. I just bought an Ultra 4. At same time I bought 4 Seagate Barracuda Green 2TB SATA 6Gb/s, (SATA 3.0), 64MB Cache, 5900RPM, 3.5". I installed the new discs in the new U...
fondy
Apr 13, 2012Tutor
Hi
thanks for your reply mdgm and PapaBear
I will check the Nic driver on the test PC and if update I will ran a new test.
I have testet the performance between the the Windows 7 32 bit PC and the Ultra, when it was connecting the gs716t switch and also connected the same PC directly to the Ultra.
The PC have 2GB ram, the nic is Intel 82567LM-3 Gigabit, the disk is ST91600412AS ATA
I used drag&drop and iometer (256kb), the file was 3GB :
Drag&drop connecting via the switch I got 75 mb/s read and 32 mb/s write
Iometer when connecting to the switch I got 64 mb/s read and 59 mb/s write
Drag&drop connected the PC directly to Ultra I got 61mb/s read and 31 mb/s write
Iometer connected the PC directly to Ultra I got 74 mb/s read and 81 mb/s write
regards
regards
