holsen1
Feb 06, 2022Aspirant
Reallocated Sector Count Increasing Daily
Hey All
I've got an NV+ with 4 x 2TB drives in it. I'm getting daily Logs showing the reallocated sector count increasing on DIsk 4 which would seem to indicate it may be close to failing. My question is if I replaced it with a HDD of higher capcity, would it increase the overall storage capacity of the NAS. I know that with the raid configuration a higher capacity Drive will be restricted to the sized of the smaller drives but the underlying question is this: If I replace 1 HDD with higher capacity today, then replace the other other 3 at a later time, will they all expand to their full potential or will they remain restricted to the original capacity of the existing drives?
Thanks!
holsen1 wrote:I've got an NV+ with 4 x 2TB drives in it.
The maximum disk size supported by the NV+ v1 (4.1.x firmware) is 2 TB. Larger drives won't work.
- holsen1Aspirant
Beautiful Thanks!
Replaced the bad drive with SD Red Got 11 years out of the old Constellation.
Decided to replace the other 3 as well, 1 at a time. So Here's the question. Once I pull these other drives, is there a way to reformat them NTFS or exFat. Just plugged one into Windows and Disk Manager doesnt recognize it.
