fondy
Apr 13, 2012Tutor
4k sector ?
Hi, I am new to readynas. I just bought an Ultra 4. At same time I bought 4 Seagate Barracuda Green 2TB SATA 6Gb/s, (SATA 3.0), 64MB Cache, 5900RPM, 3.5". I installed the new discs in the new U...
Apr 13, 2012Guru - Experienced User
Your switch collects network stats, do you see any issues there?
Note it will show you packet counts of various sizes (for instance "Packets Received > 1522 Octets"). You might check before and after each test, and confirm that jumbo frames are consistently used.
