fondy
Apr 13, 2012Tutor
4k sector ?
Hi, I am new to readynas. I just bought an Ultra 4. At same time I bought 4 Seagate Barracuda Green 2TB SATA 6Gb/s, (SATA 3.0), 64MB Cache, 5900RPM, 3.5". I installed the new discs in the new U...
Apr 13, 2012Guru - Experienced User
Ok. But if you get millions of transmission errors with jumbo frames on, then you are better off turning them off for now.
What PC are you using to test with? Laptops (without SSDs) often have relatively slow disk performance.
BTW, transmit statistics are from the switch's point of view - the switch is transmitting them, the NAS is receiving them (i.e. they are relevant stats for writing to the NAS from the PC). Keep an eye on them - the errors might not be related to jumbo frames.
