fondy
Apr 13, 2012Tutor
4k sector ?
Hi, I am new to readynas. I just bought an Ultra 4. At same time I bought 4 Seagate Barracuda Green 2TB SATA 6Gb/s, (SATA 3.0), 64MB Cache, 5900RPM, 3.5". I installed the new discs in the new U...
Apr 13, 2012Guru - Experienced User
Usually green drives lower the ReadyNAS speed by about 10%. He is seeing more than that. Though the PC is also a budget-class green machine - designed for small size and environmentally friendly construction, and not for performance. The desktop drive may be also be limiting the speed.
TeknoJnky wrote:
fondy wrote: I just bought an Ultra 4. At same time I bought 4 Seagate Barracuda Green 2TB SATA 6Gb/s, (SATA 3.0), 64MB Cache, 5900RPM, 3.5"
these drives are not very performance oriented, that is very likely why the write speed is relatively slow.
for best write speeds you want higher performance drives, ie 7200 rpm, not green, etc.
Though it might be worth playing with the ethernet adapter settings for transmit.
Ethernet flow control should be turned on.
Some of the other stuff could be experimented with, and sometimes it can help. Note the current settings first though.
Maybe try
- Interrupt Moderation Rate = off
Adaptive Inter-Frame Spacing = disabled
IPv4 Checksum Offload = disabled
Large Send Offload (IPv4)= disabled
TCP Checksum Offload (IPv4) = disabled
UDP Checksum Offload (IPv4) = disabled
