fondy
Apr 13, 2012Tutor
4k sector ?
Hi, I am new to readynas. I just bought an Ultra 4. At same time I bought 4 Seagate Barracuda Green 2TB SATA 6Gb/s, (SATA 3.0), 64MB Cache, 5900RPM, 3.5". I installed the new discs in the new U...
Apr 13, 2012Guru - Experienced User
Green disks will be somewhat slower than performance or enterprise drives. On the plus side, they should also run cooler and of course they are more energy efficient. As they seem to be working reliably, I would personally keep using them for now. The easiest way to monitor the disk health is to use the email alerts - you will get an email whenever the key SMART statistics degrade.
fondy wrote: and now maybe that the
is not the best discs for performance ?
Your goal of confirming that the ultra is 100% seems like the right one. Keeping an eye on the logs and the network stats is one aspect. BTW, if you don't have a UPS for your ultra, I would strongly recommend that you get one. Also, you should implement a backup strategy for your data. Even RAID arrays will fail sometimes.
Let us know if tweaking the network settings makes any difference.
