fondy
Apr 13, 2012Tutor
4k sector ?
Hi, I am new to readynas. I just bought an Ultra 4. At same time I bought 4 Seagate Barracuda Green 2TB SATA 6Gb/s, (SATA 3.0), 64MB Cache, 5900RPM, 3.5". I installed the new discs in the new U...
fondy
Apr 14, 2012Tutor
Hi PapaBear, thanks for your reply.
Yes I agree with the HP ultra slim PC. I will install 2 gb ram in the PC so I get 4 gb which win 7 32 bits can use and do another test.
I will also install another more robust PC to morrow and do a test.
Yes, it is good that the network is not the problem, but I dont understand why I get so much errors on the Ultra port on the switch when I use Jumbo Frames. In my network I also have two gs108t switches which is gigabit and jumbo is on, I have a total of 4 desktop PC with gigabit nic where jumbo is on. I also have a linksys e3000 router with dd-wrt, but I use this only for wlan desktops, plus some other media equipment.
Maybe I have to turn off Jumbo in my home network.
regards
regards
