lmsoares2003
Sep 17, 2011Aspirant
4tb drive support
Does anyone know if ReadyNAS will ever support 4tb drives? I'm at my limit and need to start looking for bigger drive storage. I would prefer to add bigger drives instead of getting a new system all t...
lmsoares2003
Sep 19, 2011Aspirant
Thanks for the information; it’s a shame that Netgear is apparently not going to invest the resources to increase the support for larger drives. As mentions above, 3TB drives are available and I can only assume that larger drives are only around the corner. Thanks for the information; I guess if the system no longer works to my needs I will begin to shop for other options. I plan on waiting for 4TB drives to become available before I start buying again. Hopefully by then Netgear will have changed their stance on this.
