pescatore
Sep 05, 2017Aspirant
4TB drives alternatives for RN102, not listed in HCL
Folks,
I am reconsidering a purchase of 2X4TB drives for more economical options.
I would like to stick to 7200RPM, so this eliminates a whole bunch of WD, HGST and Seagate drives.
I am really intrigued by the Toshiba N300 series, which state to be for NAS applications.
However, these models are not on the HCL. Considering the HCL is from 9 months ago, is there a chance
these drives haven't made the list yet?
I did not find relevant and recent discussion about this topic.
Thank you,
Pescatore
- Marty_MNETGEAR Employee Retired
Hello pescatore,
It does appear that you would like consider using Toshiba N300 series on your Readynas however it is not listed as compatible hard drives under HCL. The hard drives listed on the HCL are tested and proven that work well with readynas devices. We highly recommend to get a hard drives that are listed on the HCL for your readynas device. We can wait for any recommendations from community member that might have gone to the same process.Please note that NETGEAR Support can and will deny support on devices using drives not found on the official compatibility list.
Marty_M
NETGEAR Community Team - Marty_MNETGEAR Employee Retired
Hello pescatore,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team- pescatoreAspirant
Hello Marty_M,
Thanks for the details.
Rephrasing my question: Does anyone know if there is an update to the list coming soon, given that it is almost
a year old (Last Updated:11/28/2016 | Article ID: 20641)
Thanks,
Pesc
Hello pescatore,
We have not receive any notification when the HCL will be updated. We all know and agree that there are a lot of changes happen everyday in the storage community, we cannot tell it may be updated soon. For now we recommend to stick on the HCL.
Marty_M
