bsteingraber
Apr 13, 2015Aspirant
4TB HDD on ReadyNAS 2100
Does anyone know if 4TB drives work in a 2100 V2 running 4.2.27? I'm looking at getting 4x Seagate Desktop HDD 1.5 drives since they are appear to be a great choice based on testing... https://www...
bsteingraber
Nhellie wrote: You may want to check this:
https://www.readynas.com/forum/viewtopic.php?f=24&t=76764
providing that the FW that you are using is the latest, 4TB should work.
THANK YOU!!! I did not find that thread when looking.
So that answers the question if 4TB is supported by Radiator....
